Suggestions on Repurposing Film-Faced Shuttering Plywood
11/18/24
Krishnan PS
Website: http://www.superhomes.co
Hello Forum Members,
I am seeking your suggestions and advice on repurposing film-faced heavy-duty densified plywood used for formwork/shuttering in construction. While this plywood is typically reusable for 10–15 cycles, I plan to use it only 3 times for shuttering purposes.
After its initial use, I intend to repurpose the plywood for interior partition applications, such as cabinets, partitions, shelves, and cupboards. I would appreciate expert opinions on the following:
- Can the film-faced layer be effectively removed to prepare the surface for reuse in interior woodwork?
Is any special surface preparation required for repurposing?
- Is it feasible to apply laminate, veneer, or PU paint on the plywood after removing the film?
Your insights and suggestions will be greatly appreciated!
Thank you in advance.
Best regards,
Krishnan P S
India
