Hoffmann Morso NF notching machine
1/14/25
Al
For those who have the Hoffmann NF notcher for doing beaded inset frames, is it possible to miter small picture frames on this machine? Moldings that are 1/2” thick by 3/4” to 1-1/4” wide is what I’m referring to. Moldings that are profiled on face and flat on backside with no rabbet cut.
Thanks,
Al
1/21/25       #2: Hoffmann Morso NF notching machine ...
Tyler
I believe they provide a separate head that comes to a point instead of a flat to allow for mitering. That head replaces the existing haunching setup.
3/6/25       #3: Hoffmann Morso NF notching machine ...
Edwin Kelly Member
Because picture frame moldings are small, securing them properly is crucial. The standard NF notcher clamps might not hold thin pieces securely, leading to tear-out or misalignment. You may need to modify the setup or use auxiliary clamping.
