Wood copy lathe
3/25/25
Luis Jimenez Member
Website: sales@borgziiner.com
Hi, I bought a 2000 centauro tc-1200 copy lathe, months ago, and know I'm trying it, but I'm have trouble with the wood billet spinning out of the tail stock. Could anyone help me with this problem.
4/26/25       #2: Wood copy lathe ...
Angelan Member
It sounds like there might be an issue with securing the wood billet properly. Make sure that the tailstock is tightened adequately against the billet. Also, check the alignment of the tailstock with the headstock to ensure it's centered correctly. If the problem persists, inspect the live center for wear and replace it if necessary. Additionally, try adjusting the pressure applied by the tailstock to find a secure grip that still allows smooth rotation.
4/27/25       #3: Wood copy lathe ...
Luis Jimenez Member
H
4/27/25       #4: Wood copy lathe ...
Luis Jimenez Member
Hi Angelan, thank you for your response, I have check my tailstock and tighten it a few time. I have 2 knife on my copier and it spin out when the second knife hits, I think the first knife is not taking enough out. Please tell what you think.
