Cutting drywall kerfs for curved jambs
5/1/25
George Member
I'm interested in what others are using to machine the 1/8" wide x 1/2" deep kerfs in the jambs for the "California" style of interior doors without casing. The drywallers install a bullnose edging, tape and texture up to the slot in the jamb. Most here in San Antonio leave a 3/8" jamb reveal. An 1/8" wide kerf table saw will work for straight and unassembled jambs, easy peasy, but what about arched and half circle curved jambs? I have an arched french style entry door set that will have this kerfed jamb on the interior of the these doors. There should be no problem using an 1/8" slot cutter with bearing on the top to machine the arched jamb header. However, there is a jamb that the homeowners want a jamb made out of stain grade material for a passageway that originally was going to be a pocketdoor opening. This opening requires a true half circle jamb with these kerfs machined on both sides. The width of the opening is approx 36" with a height of approx 96". Has anyone here produced something like this with a slot cutter with top bearing. I suppose it depends on the overall diameter of the slot cutter to determine if it would machine a true 1/8" slot or end up with something a bit larger. I know there's a lot of knowledge here so any help would be appreciated.
5/2/25       #2: Cutting drywall kerfs for curved ja ...
BH Davis  Member
Have it made probably by someone that does this all the time. My old company is still going strong. You can reach them at:
www.curvedmouldings.com
I will add that kerf cut bends tend to work........sort of. The problem is that they usually end up with about 6" of unbent straight at the ends. If you doubt this take a 1/4" x 3' dowel and hold both ends. When you bend it you'll find the 6" to 8" at either end are straight, not curved.
5/9/25       #3: Cutting drywall kerfs for curved ja ...
Gary
I use a small router sitting upright on the edge of the jamb with a straight 1/8'' cutter .
I have designed a base, working with a machine shop, that has three bearings mounted to it that can adjust for the proper reveal on the jamb. Take your router to a machine shop and tell them what you want to accomplish. All machinists I know are WIZARDS.
6/12/25       #4: Cutting drywall kerfs for curved ja ...
Monica Chou Member
Website: https://www.zonledoors.com/
Great question — for straight jambs I also use a table saw with an 1/8" kerf blade. For curved or arched jambs, a slot cutter with a top bearing works well, but as you mentioned, the final kerf width can vary slightly depending on the cutter diameter and the radius of the curve. For true half-circle jambs, I’ve had good results using a small-diameter router bit with a bearing in a handheld router, moving carefully along a custom template. That gives better control and keeps the kerf consistent on tighter curves. Hope this helps!
8/18/25       #5: Cutting drywall kerfs for curved ja ...
oliverosalie Member
Website: https://royalestimation.com/
Cutting drywall kerfs for curved jambs can be a bit tricky, but it’s definitely one of the most effective ways to achieve a clean bend without breaking the board. The key is keeping the kerfs evenly spaced and not cutting too deep so the face paper holds everything together. Also, pre-fitting the curve before fastening helps avoid cracks later.
If you’re working on larger projects, having accurate material takeoffs and budgets can save a lot of rework. For that, professional cost estimating services are really useful, especially when dealing with drywall and other finish items.
