Tenon tooling for shaper
6/1/25
Pete
Looking for some feedback before I start searching websites and making some phone calls. I have a T130 sliding table/tenon table shaper and Im looking to get some groovers/rabbeting cutters to stack for dedicated tenons. Square shoulders, no cope(yet). I plan to have shim sets to switch b/w 1/4, 3/8 and 1/2" tenons. Ive been doing this on a smaller shaper with freeborn rabbeting cutters but would like to have something a bit bigger. Any recommendations?
Thanks for your time.
6/2/25       #3: Tenon tooling for shaper ...
Dan @ Connecticut Saw & Tool
Website: http://www.ctsaw.com
Look at the Freeborn Tool catalog straight top groovers on page 34 https://freeborntool.com/brazed-tooling-3/
You can get these in various widths in 4", 6" and 8" diameter. The hub on the cutter matches the overhang on the tips so if you put a true size spacer (1/4, 3/8, 1/2" you will get a very accurate tenon thickness. Freeborn also has the spacers in the catalog, and shims.
These will also leave a perfectly square shoulder, where as many insert style tools will have scoring inserts on the top and bottom that are set proud of the straight insert and will leave a small indentation in the corner.
Feel free to reach out if you have any questions
6/2/25       #4: Tenon tooling for shaper ...
Pete
Thanks Dan. I found those this AM and will be calling you when I get a chance.
6/3/25       #5: Tenon tooling for shaper ...
Joe Calhoon
I don’t mind the spurs on tenoning disks. They leave a cleaner cut than groovers without them and the little indentation is not noticeable in most cases. All my disks from the Garniga Multiuse cutter shown to the 320mm diameter Tenoner heads have the spurs.
View higher quality, full size image (2822 X 3763)
View higher quality, full size image (2704 X 3606)
6/22/25       #6: Tenon tooling for shaper ...
David R Sochar
Insert tooling would be a good choice in my opinion. Several good makers out there. I have used Charles GG Schmidt for brazed dedicated tenon cutters, with excellent results. But, like I say, inserts would get a close look today.
Like Joe, I am not bothered by the spurs. An old boy I worked with explained that the spurs 'cut the wood before it knows it is being cut' and therefore avoids tearout.
My book on Building Custom Wood Doors has further info and considerations.
