brushed texture on European rift white oak
8/14/25
Revel Woodard  Member
Which wire head should I use for the Superbrush 24"? My inclination is the lighter gauge one would do the trick, and the heavier one would be too aggressive, especially on the edges of the doors and panels. I've got about 60 linear feet of floor to ceiling cabinets. Have settled on 1/18" rift oak veneer. I made samples using the handheld Makita brush, they look great and would like to replicate that. I'll be doing a captured solid wood edge, and could cut it down after passing though the machine, but would like to avoid that because I'd like to pre brush the edging. Ideally I could cut a 1/16" radius prior to passing doors through, and minimize cleanup and hand work. Would the heavier brush be too aggressive on the edge? If a light / medium texture can be had with the heavier brush by tweaking fede rate and brush speed, I'd prefer that as long as it doesn't;t start pulling / splintering wood at the edge. I want to pull out the softwood without scratching up the latewood. Aside from purchasing new, I'm also looking in to rewinding my existing nylon brush, provided I don't need it to chase all the panels after wire brushing. After my tests with the Makita, it seemed to leave a nice buffed finish without the nylon brushing step. FWIW I'll be dyeing, staining, and spraying a waterbased poly.
