brushed texture on European rift white oak
8/14/25
Revel Woodard  Member
Which wire head should I use for the Superbrush 24"? My inclination is the lighter gauge one would do the trick, and the heavier one would be too aggressive, especially on the edges of the doors and panels. I've got about 60 linear feet of floor to ceiling cabinets. Have settled on 1/18" rift oak veneer. I made samples using the handheld Makita brush, they look great and would like to replicate that. I'll be doing a captured solid wood edge, and could cut it down after passing though the machine, but would like to avoid that because I'd like to pre brush the edging. Ideally I could cut a 1/16" radius prior to passing doors through, and minimize cleanup and hand work. Would the heavier brush be too aggressive on the edge? If a light / medium texture can be had with the heavier brush by tweaking fede rate and brush speed, I'd prefer that as long as it doesn't;t start pulling / splintering wood at the edge. I want to pull out the softwood without scratching up the latewood. Aside from purchasing new, I'm also looking in to rewinding my existing nylon brush, provided I don't need it to chase all the panels after wire brushing. After my tests with the Makita, it seemed to leave a nice buffed finish without the nylon brushing step. FWIW I'll be dyeing, staining, and spraying a waterbased poly.
10/21/25       #2: brushed texture on European rift wh ...
rempredo Member
Website: https://www.medipakiet.pl/blog/czy-wodobrzusze-jes...
For your Superbrush 24", the lighter gauge wire head is recommended for your use with 1/18" rift oak veneer and the delicate edges on your doors and panels. The lighter wire will effectively pull out the softwood grain without being too aggressive, which helps protect the veneer edges from splintering or damage. This aligns well with your desire to pre-brush the solid wood edges and minimize cleanup, allowing you to cut a 1/16" radius before running the doors through the machine for a clean finish.
Although a heavier gauge brush could yield a stronger texture, it risks being too harsh on the edges, especially if the feed rate and brush speed aren’t perfectly dialed in. Since you want to avoid pulling or splintering the wood, the lighter wire gives you better control with less risk of damaging the softwood or edges while still providing an attractive texture. If you adjust the brush speed and feed rate carefully, you might achieve some variation in texture but the lighter gauge remains safer for your precise needs.
Regarding your nylon brush, rewinding it is an option if you want a less aggressive finish after the wire brushing step. Your tests with the Makita tool suggest the nylon brush can provide a nice buffed finish without creating scratches or damage, which complements staining and dyeing before applying water-based poly. Overall, go with the lighter gauge wire head for delicate work on rift oak veneer edges with the Superbrush 24", and consider the nylon brush for finishing touchups.​​
