Subject: Re: optimizing saw
optimizing saw
12/1/16
Brian
I'm wondering about the claim by manufacturers of optimizing saws that we can downgrade our material purchasing a step or two from select lumber. We make entry doors and require stable moisture content and wood that is virtually 100% free of defects. Can we use a lower grade of material and still have the stability we need for doors?
12/1/16       #2: optimizing saw ...
John S  Member
The grade of material should have nothing to do with the moisture content, it is either dried properly or it isn't. I wouldn't accept ANY grade of lumber that isn't dried properly.
The difference will come in when you try to get your components out of the lumber. You don't say what length/width you need, but if you look up the NHLA grading specs, it will tell you what to expect from each grade. If your length/width requirements can be met with something less than "select & better", then give it a try. But don't expect to get seven foot clear lumber from No. 2A grade.
12/2/16       #3: optimizing saw ...
Bill Member
Couldn't you buy a bunk or two and manually defect it? From that you could determine the yield. It would be slow and ponderous but worth the effort. You would hope the software the the system could do a better job of optimizing the material.
12/2/16       #4: optimizing saw ...
I would imagine the benefit being a bit less in an operation using larger parts. You would have to have the need for all the low grade and be moving enough volume to use it. Long, thick, clear, solids would seem tough to strip out of packs of #1 or #2. Just my guess.
