Subject: Re: tax deduction for church cabinets
10/15/20
Mark Member
I was approached by my church to replace cabinets in the church residence. I intend on charging just the cost of materials. They have a bid from a GC which is 4 times higher than my material costs. Using the GC's numbers as "market value", is there any combination I can use to take the difference of the GC's numbers and mine as tax deductible donation? The law states you cannot take a deduction on services to a charitble organization. Thoughts?
10/15/20       #2: tax deduction for church cabinets ...
Are you talking about inflating your bill to the GC's amount (or close) and only billing the church for the materials and claiming the entire offset amount (labor) as a charitable donation? The invoice amount I believe would still have to come from the institution. You cant fabricate your own figures.
Seems you should have presented this question to your accountant. 4x your projected material (which is likely way low) seems pretty fair for the cost of a project.
10/16/20       #3: tax deduction for church cabinets ...
Mark Member
Yes, that was my original intent. To deduct the difference on what the GC's cost estimate and my material costs.
After looking into it further, donated services are not tax deductible. They used to be but this changed in 2011.
10/16/20       #4: tax deduction for church cabinets ...
D Brown
Check it out for sure , I was under the impression you can't deduct the labor but yes on products.
10/16/20       #5: tax deduction for church cabinets ...
Mark Member
That is correct, the cabinets alone are deductible when donated to a charitable organization, an example would be if I donated cabinets to Habitat for Humanity or a church, those are tax deductible. How value gets assigned I'm not exactly sure.
my services to build and install are not.
Since my material costs in any cabinet job are deductible as expenses I think the easiest thing for me to do is just do them for my cost of materials.
10/16/20       #6: tax deduction for church cabinets ...
D Brown
I would ask your tax person about the deduction for donations and how that works to be sure.
10/16/20       #7: tax deduction for church cabinets ...
D Brown
Kind of interesting, If I pay for a set of cabinets then donate them how much can I write off ? The same prolly is true for most items.
10/16/20       #8: tax deduction for church cabinets ...
Only the cost of materials are deductible as a charitable deduction. I suppose that is the law to avoid huge inflated deductions.
10/17/20       #9: tax deduction for church cabinets ...
Jeff  Member
In the past I’ve always just invoiced the church for the full amount and then wrote them a check as a charitable donation for the same amount or whatever portion I chose to donate. Seems to take out any gray area if there is ever an audit.
10/26/20       #10: tax deduction for church cabinets ...
Marv Member
Your labor is not deductible. Since you are reimbursed for materials, there appears to be no deduction. This has been the same since I started doing taxes 40 years ago.
I always tell people you don't get a deduction unless you write a check. For instance you write a check for cabinets and give them to the church.
11/6/20       #11: tax deduction for church cabinets ...
Harry DeVrieze
Charge the church full price. They pay you full price. Then write the church a check for the difference between your material and your labor. Then deduct that "donation" on your taxes. Its that easy. Contract price . Do not itemize or break down material and labor on their invoice.
Regards
Harry DeVrieze
Lakland Stair & Millwork
11/9/20       #12: tax deduction for church cabinets ...
Marv Member
Case 1. you charge them 50 for parts and they pay it. you break even.
Case 2. you charge them 50 for parts and 50 for labor. they pay it. you break even.
You deduct parts in both cases.
    • TradeJobPlacement.com
    • Impact Search and Placement
    • WOODWEB, Inc.
