Subject: Re: job manifest
job manifest
4/28/21
scott
When loading a truck for delivery what method of accounting do u use to verify all parts for installation are on truck. We've had a few jobs where vital parts did not make it to jobsite at the start.
4/29/21       #2: job manifest ...
ExPat Member
The shipper has a checklist of items required. Everything has a barcode and gets scanned in as it is loaded on the truck. The scanned in list is checked against the load list. We don't currently but soon will be making labels for the sundry items - screws, shims, glue and such.
5/10/21       #3: job manifest ...
Mitch Suber
Website: http://Suber custom shutters.com
We use two separate checklist, one for tools and misc items needed to perform the installation. The checklist is usually the same for every job. Then we use a checklist for the product and related items, with a number count for panels, frames, and other components. And then we designate a person who is responsible for each list, who will check at the time everything is loaded. Often it’s the same person, most likely the installer. We have found that counting on more than one person to be responsible for loading, creates a situation where each person thought the other one loaded the forgotten item.
5/13/21       #4: job manifest ...
cabinetmaker
Checklists. They get printed out with shop drawings.
Our stone shop works off a running checklist that is 5 pages long but works through from client contact to the client signing off the job at install, including photos.
Our guys run rotary percusion to install in tile on bathroom walls and it’s hell enough that those go on the truck with the levels. They are on the list right after screw guns and screw boxes.
    • TradeJobPlacement.com
    • Air Handling Systems
    • Impact Search and Placement
    • INNERGY
    • Better Vacuum Cups, Inc.
