Subject: Re: Power Factor correcting capacitors
7/2/21
Bob Member
It seems my power factor is rather low (~75%). I am getting rather spectacular electrical distribution charges. Has anyone ever put in power factor correction capacitors? If so, how successful was it in correcting power factor?
7/3/21       #2: Power Factor correcting capacitors ...
Rob Young  Member
We did this at our Merillat plant in 1990. It did result in a reduction of our electric bill.
7/3/21       #3: Power Factor correcting capacitors ...
Bob Member
Rob,
Thanks for the response. Wondering what you did. Did you put in smaller units at each of the machines or a large central unit at the overall power source. If you did a larger central unit did you use a fixed capacitance unit or an automatic variable capacitance unit? Did you get someone to help size the whole thing or just take a stab at it? I realize 1990 was a long time ago...but any recollection of what worked will be appreciated.
7/4/21       #4: Power Factor correcting capacitors ...
cabinetmaker
Our older Travini 40 hp vac pump and 15hp collector were just such pigs, that when we replaced the cnc it came with 2 pumps with soft starters and staggered starting. Before I hooked up the newer used collector I purchased a VFD on eBay for 300 bucks. I run the collector currently @ 93 percent
Newer machine 800 surcharge off our bill
I hadn’t yet bought the VFD for our travini when I jumped on a good deal for our new cnc with sweep
Our local utility did an audit, but it took almost 1 year for the 800 charge to come off.
My friend had a rather unusual case snd fought the utility tooth and nail and they together lots of enomlies in the panels spiking his consumption rates iratically
I would highly recommend, in this economy to call them, have them check lugs on their side of the meter and you check your meter side and every connection in your boxes, service disconnects, etc. Also a good amprobe, spread sheet can give you good anlytics as to what is going on with each machine that is operating when, how long to do a process etc
    • TradeJobPlacement.com
    • WOODWEB, Inc.
    • Impact Search and Placement
