Subject: Re: No one use a beam saw?
9/9/21
Brian
Over the years I have noticed that there are very few if any questions or references concerning the use and operation of beam saws. No chat about the various optimization applications . Why is that?
9/9/21       #2: No one use a beam saw? ...
Nathan Wesseling Member
Hi Brian,
You're right, you don't see many. We use a beam saw here though. In combination with a rail and pod as well as a vertical machine for smaller parts. This works really well for us, as we mainly do large production runs, cant beat a panel saw that can cut 4 sheets of base gables at a time.
9/9/21       #3: No one use a beam saw? ...
Bruce H
I use my beam saw almost every day. Optimize the cuts as I go. Tried software but it was a waste of time. My scrap/waste is very little.
9/9/21       #4: No one use a beam saw? ...
Mark Elliott Member
My beam saw was one of the best machines I have purchased.
When you have to cut up a lot of sheets a day of various panel products, it's the only way to go.
I think the reason you don't see a lot of questions about them is that they are pretty reliable machines, and now that they are tied in with network cables to the manufacturers, they can get you up and running if you have an issue over the phone.
9/10/21       #5: No one use a beam saw? ...
Hen Bob Member
We use ours everyday , much faster and safer than another way to cut sheets.. We also don't bother with the software, its fast enough to just type in the cuts you need
9/10/21       #6: No one use a beam saw? ...
I thought this was settled a long time ago in that a CNC router was more efficient because of reduced material handling.
With the exception being when you book cut, i.e. what percentage of your cutting is book cutting?
9/11/21       #7: No one use a beam saw? ...
I think thats one debate that will never be won, one way or the other. I think both processes have their place, again depending on what the rest of your process looks like and what type of work you do. We do production cabinets as well as closet parts, I would hate to run a lift of closet parts on a nesting machine. I fell like for us the flexibility of a beam saw and pod machine far out ways any productivity increase a nesting machine may or may not give us.
9/12/21       #8: No one use a beam saw? ...
In the farming world comparing a cnc to a beam saw would be like comparing a threshing machine to a modern combine, there is no comparison, a beam saw is more efficient and a saw cut edge is also cleaner and nicer to accept edge banding.
A cnc is a machine of choice for a lot of companies as it does so much. But they are not designed for production cutting of sheet goods and there is a lot more waste.
9/12/21       #9: No one use a beam saw? ...
pat gilbert
Even Alan F changed his mind on this and admitted that the router was more efficient, unless you are book cutting.
Although I think he may have changed his mind with the advent of beam saws with grippers that allow 3rd phase cuts
The rejoinder then is that we always book cut our ends
But if you're not cutting books IMO the router is more efficient
And the router is a lot better at cutting radiuses
I guess this is another episode of what Nathan is talking about
"I think thats one debate that will never be won, one way or the other."
10/2/21       #10: No one use a beam saw? ...
I would take a good Striebig type panel saw over a beam saw.
    • TradeJobPlacement.com
    • Air Handling Systems
    • Impact Search and Placement
    • Better Vacuum Cups, Inc.
