Subject: Re: Pole barn vs steel building
9/6/18
Matt Calnen
Hello all, I am looking into having a shop built, roughly 3000 sqft. I am looking into my options and am looking at polebarns and steel framed buildings(sure as General Steel) as options. It looks like steel frame buildings are more cost effective to put up, but what are the negatives with them? I live in northern Michigan and can see heat loss through the heavy metal frames being a drawback, and having to frame interior walls to mount stuff to as the inside of metal buildings are angled in at the top. For those of you who have a metal building, do you wish you had gone another direction? What are pros and cons of these buildings? Thanks
9/6/18       #2: Pole barn vs steel building ...
I have a steel frame metal building. Mine has the ridged frame design (columns angle in at top) That is a problem where I have steel racking for lumber. It requires the racking to be held out from the wall. I would prefer going with the post and beam steel frame. They cost more and can't span as wide of building. My clear span is 80' (actual 78' inside.) I'll assume that the pole building is also skinned in sheet steel and would have plastic faced insulation exposed like a basic steel framed building. Not good for insulating value or getting damaged. You will need to have an interior wall surface (steel, plywood or gyp.) That will likely require more framing for the pole building. If you skin the inside you can go with better (more) insulation than the plastic faced stuff. I don't care for the sheet metal skin outside. Too easily damaged. But it is cheap.
Put in a 6" concrete floor with perimeter insulation. Much more crack resistant (than 4") and better for a CNC router.
My building has 4" of insulation. The most they would put in at the time it was built. It is compressed to 1/2" +- at all frame locations, not good! But that would also be the case with the typical pole shed.
If I was starting over, I'd have a concrete tilt up with sandwich construction, foam core. For a small building wood roof trusses and standing seam roofing.
In your design, take into consideration possible future expansion, provide for cross ventilation (overhead doors on opposite sides,) roof or gable vents, natural light (high mounted windows,) locating the compressor, refrigerated drier & vacuum pump in their own (vented) room to keep the noise down. Dust collection outside. Provide for electrical cord reels in many places on the ceiling. 120 Volt outlets every 10' around the walls. Put in more electrical service than you think you need (its way cheaper than adding latter.) Sooner or later you will want 3 phase. It can be done with a converter. Smaller motors can have VS drives installed that will provide 3 phase.
9/6/18       #3: Pole barn vs steel building ...
To make a steel frame building energy efficient, you have to build a wooden building inside it. Pole barn at least has a wood frame with purlins. But the one we had put up on our farm, had the posts starting to rot. It is one that has laminated 2x lumber for the posts. I'd build a traditional wood framed building on a slab if I was doing that.
9/7/18       #4: Pole barn vs steel building ...
Puzzleman Member
One thing that I would definitely do differently is to put radiator heat in the flooring. The heat would be consistent, no filters to change due to dust and very few cold spots due to air flow.
9/7/18       #5: Pole barn vs steel building ...
David R Sochar  Member
3,000 s/f? I'd build it as a stick framed wood building. Or timber frame it. 2x6 walls for insulation, and whatever you want for the ceiling. Put up some decent 1/2" ply on the inside walls and you have a very nice shop. Paint the ceiling white. You will have a very familiar building with wide versatility. Plan to add on.
Each building type has its ideal cost range. Around here, tilt up concrete is only used above 12,000s/f. Metal buildings down to about 4,000s/f, and Pole barns from 2,000 s/f up to 20,000 s/f. List out your costs for each of the types and you will see.
9/7/18       #6: Pole barn vs steel building ...
Jim Herron
Have you considered hollow concrete block walls and wood truss or structural insulated panel roof with metal R panel. You could do spray foam insulation with trusses and metal roofing.
+1 on the radiant floor heat.
9/7/18       #8: Pole barn vs steel building ...
Gary Member
Three years ago I had a stick built 16' high 73'x188' built with steel inside and out, infloor heat, overhead doors for ventilation and door use, 5" of spray foam and plenty of windows and man doors. Takes little to heat (northern Iowa) and is a pleasure to work in. The white interior steel walls and ceiling are great. Nice and bright, easy to clean off and very pleasant to work in. I can't think of anything I would do different.
9/8/18       #9: Pole barn vs steel building ...
Paul Miller
I'm in Northern Michigan, Traverse City area. I built a 12,000 sq ft Steel building in 2002. I think you will find, for the size building you are considering, steel is too expensive. Everything has to be engineered. A pole barn I'm sure is the least expensive. The buildings have different uses.
My shop has 24' high ceilings and I can store lumber high with a 16' three stage mast forklift. I also have a loading dock which I think would be difficult with a pole building. Steel buildings have a lower pitch on the roof. My pitch is 1' in 12', So, we get ice accumulation along our eve's and that can be dangerous.
Driving around N Michigan, you will see damage along the base of the walls on steel buildings. This is caused by ice accumulating along the eve, when it heats up, the ice slides out to about three feet and then breaks off, crashing down and it falls back against the building. That is the primary reason that you see concrete block on the lower level of these steel buildings. I think you can avoid this with a different pitch roof.
If you do build a Woodworking shop, check the codes. I think they have changed. Also, check with the Fire Marshal. They will review any plan you have and you can go through the whole process and have it rejected by the Fire Marshal.
The comments above are all good. I think it really depends on your budget and long term goals.
If you want to see my building, send me a message.
9/8/18       #10: Pole barn vs steel building ...
Some good responses. About under floor heat, using headers along the perimeter where each run is supplied is a good idea. That way if one run gets damaged you can cap it off easily. Its not easy to locate a bad spot when it is all laid as one run.
High ceilings, yes. I have 18' side walls and wish I had 20'. Lots of stuff gets hung there: lights, sprinkler pipes, ducts, electrical, cord reels, heating... and it is nice to be able to end for end a board w/o hitting something. If you have a forklift tall racking makes more storage. White walls and ceiling will help with lighting, a lot. Epoxy the floor for easy cleaning and for light reflectance. I like windows, they do drain heat but do provide nice lighting ambience.
For those of you planning a larger shop: If I was doing it again, I would put in buss duct for power distribution. A loading dock lets you roll stuff in & out and use the forklift on heavy items.
My dad had a concrete block shop. Cores were filled with insulation but ice would still form on the inside! Foam insulation is efficient but needs to be covered with something fire retardant.
Concrete: tilt up or poured in place is the most durable but expensive. Also more difficult to modify. Stick frame on a slab is probably your best bet for the size you are talking about.
9/8/18       #11: Pole barn vs steel building ...
Paul Miller
I didn't have the money to put in floor heating. Since, I have added a wood waste burner and run heat lines through the building. My shop is not well heated. We vent air when finishing and we do not have make up air so it is cold at times.
One thing I did do was to run my electric under the floor. I did a machinery layout with AutoCAD and I had the plumber run PVC pipe on the ground before we poured the concrete. This saved quite a lot with the electric. I worked this out with the electrician as well. If you do that, be sure that the electrician leaves a thin rope in the pipe in the event you want to add electric and my pipe is 2".
9/9/18       #12: Pole barn vs steel building ...
Charles
There is a trick to getting a thin rope through a PVC pipe if one is not put in place as the pipe is first installed.
Three things are needed:
1) "Pulling Line" is a thin polypropylene string; sold at the big box stores in the electrical department
2) Plastic shopping bag; the kind that stores use at the check-out counter
3) Shop vacuum
Tie the bag to one end of the line and stuff the bag into one end of the pipe. Use the vacuum at the other end of the pipe to suck the bag through. Be sure that enough string has been unwound and tangle-free as the vacuum will pull the bag through very quickly.
Use the pulling line to pull the electrical wiring through the PVC.
If the pulling line is not strong enough (it is pretty strong by itself), use the line to pull a heavier rope through first, then use the heavier rope to pull the electrical.
We did this on a 100'+ underground run. The bag pulled through the 1.5" PVC within a couple of seconds.
Good luck on the new building.
9/9/18       #13: Pole barn vs steel building ...
I would look at SIPS to build the whole building. Definitely for the roof. They span something like 10' on a roof. You can frame the roof with large LVL and a structural ridge.
After you do the math of 2x6 + sheathing + insulation what's it compare to SIP walls.
There are steel buildings the vertical walls. What is the cost difference?
There are also the newer insulated block form things ICF.
I would never build a house or shop without a SIP roof.
9/9/18       #14: Pole barn vs steel building ...
Matt Calnen
Thanks for all the input. One of the reasons I was looking at a steel building is most polebarn builders around here are very busy, have a long waiting list and are getting to be a bit pricey(I was rough quoted $30 to $35 a sqft for my shop. Included cement, two overhead doors, two man doors, 4 windows, building site work and insulation). I was hoping a company like general steel with mobile crews that travel and have a standardized system in place would be a better way to go.
Stick framing I assume would be more expensive as the footings up here need to be 42” deep
Having worked in shops with infloor heat, I think I would do cast iron baseboard heat as it doesn’t make my feet sweat.
The SIP framed building is an interesting idea, however I don’t know if anyone who does these in my neck of The woods. I Think Imore research. Thanks for all the input
9/9/18       #15: Pole barn vs steel building ...
Karl E Brogger
Website: http://www.sogncabinetcompany.com
Steel buildings you're stuck building a building, inside your building to finish it off. Somebody already said this. If you want a cheap structure, and aren't planning on finishing it off, steel is a really economical way to do it. Plus you can more cost effectively do a bigger span than wood trusses.
I'm assuming this is fairly universal, going much more than sixty feet on a truss gets real expensive real quick.
I'm not a fan of pole buildings. You've got wood in the ground, it can rot.
You live with frost, which mean it will get under your slab and it will cause problems.
My building is 60x132 with a 16' sidewall. Stud construction 2x8 16" OC. Sheeted on the outside, and FRP panels sheeting the inside. FRP, (fibre reinforced panel), is like the stuff they use in hog/dairy barns. It was expensive but it's durable and I didn't have to paint. I figured it was a wash in cost over painting OSB, and its more durable than paint. I ruled out sheetrock, it would just get abused too easily.
R25 insulation in the walls. 4/12 trusses 4' OC, I think we blew in to about a R45 in the attic.
Steel roof, steel wainscotting, and I did LP Smart siding on the field of the walls. I did regular siding since the dirtbag little town I built my shop in doesn't need another boring steel box in town. It looks nice
My building sits on a block foundation. I wanted to do a poured foundation with foam in the middle so the thermal break goes all the way to the footing, but I was tapping out my budget anyways. I'm assuming Michigan has similar standards and you have a 4' frost footing.
Money no object? I would've done tip ups. I looked into it and for my building the panels were $120k. No trucking, no setting. Just the panels. For my needs, this was the most cost effective way to go. If you're building in an industrial park, they generally have covenants that would prohibit a wood structure. Then you're stuck with steel, block, or tip ups. I'm not a fan of flat roofs though. Snow load and ice are something to consider and a pitched steel roof handles that about as well as anything.
Somebody said tip ups are hard to modify. Not that I've seen. Most of the time they yank them out of the ground and re-use them. Then keep on rolling with new panels.
In floor heat is a no brainer. Put the pipe in the slab, buy a boiler later. There is no better heat source for a wood shop. You also have multiple heat sources for a boiler. Electric, propane/NG, or a wood boiler. The pipe is cheap, the install is too. Spend the money now at least on that part.
I wouldn't bother putting conduit in the floor. You aren't going to put a piece of equipment in that one place forever. Pipe it overhead in EMT with cord drops and changes are cheap and easy. Want to bump something 2' one direction or another? You probably won't even need to change anything. A wood shop, or any business for that matter, is a growing changing organism. The size you're looking at is small (as is mine), and it's needs will change. You will have "ah ha" moments and get different, better, bigger equipment to avoid getting raped by the government and to provide a better product at a lower cost to your clientele.
Bring in a bigger service than you need. (Already been said too). I brought in 800 amps of 480v. I'm sitting pretty good right now, but I've got room to expand, both electrically and physically, and I can pull another 200 amps out of the transformer if need be, (might be 400 amps, I don't remember). That's probably more juice needed than my willingness to grow big enough to use it. But you never know. If the utility company scoffs at you, lie. Lie for longer. Tell them you're planning on growing aggressively. Bring in 480 too. 208/240 goes fast. It's cheaper now than later.
9/10/18       #16: Pole barn vs steel building ...
Paul Miller
You will not come close to building a 3,000 sq ft building for $35 per sq ft. There is so much more to a building than a shell. You will probably be closer to $75 to $80 per sq ft. You say this includes concrete, how much, 4" 5" or more? Does this include Site Plan? Probably not. How much for Permits?
My building is a Steel and block building, 12,000 sq ft. With Site Plan, Plan Review, Fire Marshall Plan Review, Township Plan Review and Foundation Permit and Building Permit, I had over $25,000 invested and we hadn't even cleared the lot. And, this was in 2001. And, to defer some costs, I hired the Engineer for the Site Plan, I meet with the Township, I meet with the Engineering Company that The Township hired to review my Site Plan. I meet with the Fire Marshall and I made my own presentation to the Township Board.
My builder suggested that we not tell the Township that the building was being built for a Cabinet/Woodworking business. In retrospect, I am glad I did not follow his advice. I had to have Dust Proof electric and Explosion proof electric in the Spray/finishing area. Years later, when OSHA, MiOSHA in Michigan walked into my shop and told me I had to have Explosion proof wiring everywhere, I showed them my permit and plans and that argument went away. The Fire Department makes and inspection about every five years, so you will need their approval.
I have a friend that got a quote for a 12,000 sq ft Steel and block building and it was in the $130 sq ft range. I built my building for about $60 a sq ft, but that was 16 years ago. My Insurance company put a replacement cost on my building at $900,000 which would put the building at $75 sq ft, That figure does not include Site work, septic, well, roads, parking, or sidewalks.
I hope this helps.
9/12/18       #17: Pole barn vs steel building ...
Kevin
We are in the process of building a 3,000 SF building ourselves. We got footers poured this week so we're about done :)
I checked every type of building possibility there is and debated the cost vs a multiple of different factors. For this size shop, stick built construction with a slab was the best way to go. We are adjacent to a residential area (we were allowed a zoning ordinance) so our shop will look very much like a house which vinyl siding, brick wainscot, architectural shingles, etc.
I have a close friend that is a builder and we did some bartering and it's still an expensive venture. We own the land and the straight cost for the building alone works out to a little over $50.00 per SF. I'm not paying any mark-ups on material or labor.
The metal building packages like General Steel quoted prices around $70.00 per SF and that didn't include any electrical or plumbing. I believe I would have preferred the metal truss and metal clad walls and roof over the stick-built but the cost difference was just too much for me to swallow this go around.
9/12/18       #18: Pole barn vs steel building ...
Hope you spray water based Kevin. If you start pumping out solvent based conversion varnish fumes next to some houses, I bet you get a visit or 10 from zoning.
9/16/18       #19: Pole barn vs steel building ...
Garen
I built my shop in 2012. One man shop 66' wide X 40' long pole building with a raised cord truss to gain a little extra height in the middle of the shop. Built it wider then long to not effect the neighbors view when I add on. So far i have been extremely happy with the building. Mine is located on my land where my house is. We went threw all loops the permits and zoning changes to get it zoned properly. Have dedicated space for office, bathroom, spray area, finish mixing storage area, and a portion of the side to park truck, skid steer and holds air compressor/dust collector. I did infloor heating and spray foamed walls blown in roof. Well worth the extra cost Only thing i would have done differently would be to sheet the outside of the building before puting up the sheet steel. We had hail damage and had to get it fixed. Alot more work getting steel off and trimming foam to fit the new sheets on the sides of the building. Also the foam pushes out a bit on the steel causing a bubble look was kinda pissed after they sprayed it and thats what you see when you drive up to it. I fully finished the interior. 8' steel on exterior walls in the shop areas and drywall on the rest of walls as well as the ceiling. I did this also for resale if we ever sell. Rather then steel on the inside or just seeing the white insulation. Whatever you end up going with think ahead for future add ons and machine placement changes.
View higher quality, full size image (1032 X 581)
2/23/22       #20: Pole barn vs steel building ...
Marcus Reid
6/10/24       #21: Pole barn vs steel building ...
Kevin Brown
Website: http://www.qualitysteelbuildings.com
When choosing between a more traditional barn-style pole building and a modern steel building, several things should be considered. Both have their benefits, but the right choice will be based on your specific situation and priorities.
Construction and Materials
Pole Barn:
Usually made up of wooden posts buried in the ground or set on concrete pads.
Roof and walls are often metal panels, however, and are simply applied to a wood framework.
Cheaper up front, especially for small structures.
Can go up faster with fewer construction skills needed.
Steel Building:
Made from steel only, including the framing, roof, and walls.
Provides greater strength and durability.
More expensive initially, but costs less over time to maintain, which makes them more affordable in the long run.
Prefabricated kits can reduce the labor costs of construction.
Durability and Maintenance
Pole Barn:
The wood framing can be subject to rot, pests, and weather exposure.
Requires more periodic maintenance and inspections.
May not hold up to severe weather like steel buildings.
Steel Building:
Highly resistant to pests, rot, and fire.
Requires little maintenance when compared to wood.
Built to last under extreme weather conditions, like heavy snow, strong winds, and earthquakes.
Versatility and Customization
Pole Barn:
Easier to modify or expand with wood construction.
Can be tailored to fit almost any use or needs; agricultural, residential, or commercial.
Visually fits in with traditional landscapes in rural settings.
Steel Building:
Highly customizable for size, layout, and other features.
Suitable for a wide range of uses, from industrial warehouses to residential garages and commercial spaces.
A more modern look that can be styled to suit modern design tastes.
Cost Considerations
Pole Barn:
Lowest first-cost system, which provides the most cost-effective building.
Potential for high long-term maintenance costs.
Steel Building:
It provides the lowest overall cost where large, single-story buildings are important.
Because they are typically more durable and lower maintenance, they have a much better return on investment in the long run.
Often a more affordable solution for larger buildings, as the design leverages the smaller structural members used.
Steel is one of those recyclable and durable materials that reduces frequent replacements.
It will potentially have a lower environmental impact over the lifespan of the building.
Conclusion
In conclusion, there are good aspects of both pole barns and steel buildings. Pole barns achieve a lower initial cost and easier modifications than steel buildings. On the other hand, steel buildings offer superior durability, lower maintenance, and better value in the long term, especially when considering larger or more permanent structures.
As such, the decision of either pole barn or steel building rests on the need, other specifics, budget, and requirements toward a long-term goal. Think about which factors are more important to you and weigh the pros and cons of the options before reaching a decision.
7/31/24       #22: Pole barn vs steel building ...
Betito Ochoa  Member
Website: https://www.vikingbarns.com/
When deciding between a metal and a wood building, there are several key factors to consider:
Cost
Aesthetics and Customization
Environmental Impact
Ultimately, the choice depends on your priorities—whether you value durability and low maintenance, cost efficiency, or aesthetic flexibility. Consider the specific needs of your project and your long-term plans before making a decision
8/26/24       #23: Pole barn vs steel building ...
Kevin Brown Member
Website: https://www.americanmetalbuildings.com/
I appreciate the detailed breakdown you've provided. Managing costs while maintaining quality is always a challenge, especially in this industry. Your insights on balancing these aspects are spot on. It’s helpful to see how others are navigating these challenges. Thanks for sharing your experience!
1/17/25       #24: Pole barn vs steel building ...
Nathaniel White Member
Website: https://whitestarbuildings.com/
Great discussion! We've built steel buildings and can attest to their durability and long-term value. Their resistance to pests, fire, and extreme weather makes them a solid investment. While they require a higher upfront cost, the low maintenance and longevity more than make up for it. Steel buildings are also highly customizable, which has been a game-changer for projects needing flexibility.
9/2/25       #25: Pole barn vs steel building ...
Aaron Member
Website: https://northernsteelbuilding.com
A pole barn is generally more affordable upfront, easier to insulate with traditional materials, and gives you flexibility with interior framing. A steel building, on the other hand, is stronger, longer-lasting, fire-resistant, and low maintenance. The main drawbacks are higher initial cost, potential heat loss through the framing if not properly insulated, and needing extra work for interior finishing. In northern Michigan, if you insulate well, a steel building can last decades with very little upkeep, while a pole barn may require more maintenance over time.
    • WOODWEB, Inc.
    • Impact Search and Placement
    • TradeJobPlacement.com
