Subject: Re: Duct work
Duct work
5/8/22
Dror Lev-Har
Looking for a manufacturer of duct work for new shop with cnc, edge bander, boring machine.
5/8/22       #2: Duct work ...
Not sure any manufacturers sell directly to the customer. The ones I know of sell through dealers.
5/8/22       #3: Duct work ...
Oliver
https://airhand.com/shop/
5/9/22       #4: Duct work ...
Jim Herron
I purchased my spiral ductwork from a HVAC contractor friend of mine
It was made fairly locally
I'd check for local sources thru HVAC supply houses
I'd imagine shipping long lengths of spiral pipe could be cost prohibitive
5/9/22       #5: Duct work ...
Jim Herron
Also I've used o neida-air.com and airhead for fittings and straight snap seam pipe
I'd steer clear of the residential gauge pipe and adjustable elbows
This stuff takes some abuse so the heavier gage stuff is worth the extra expense
Oneida offers layout service if needed
5/9/22       #6: Duct work ...
Peter Rusterholz
I used https://blastgateco.com a few years ago when i moved into a new shop.
Thought they were reasonable, helped with layout and had quick shipping.
5/9/22       #7: Duct work ...
Scott Gibson Member
Website: momentumwoodworks.com
I used Blastgateco.com.....all quick clamped together. It works phenomenally but it is not cheap!!!!
5/10/22       #8: Duct work ...
Derrek
Website: http://www.closetsr.com
The clamps together stuff is the way to go. I had some that I had bought through a local vendor. When we moved shops I pulled it out. I ordered everything I needed to complete the installation from Grainger.com. They had everything online and it would show up next day. I added manual blast gates and elbows to what I had.
I used the same setup to hang it as I did for my airlines in video below
Airlines install
5/11/22       #9: Duct work ...
Rob Young  Member
Derrek, nice choice on the airlines for multiple reasons. Black pipe will rust. The rust will decrease the air flow through the pipes, especially in fittings. A 0.75 ID elbow can end up with a 0.25 ID when they rust, greatly reducing the cfm through the pipe. The contamination from the rust will make it's way through your system and into your pressure gauges.
The aluminum is also light weight and easy to work with. Our showroom is piped with the rapid air product line. ~Rob
5/12/22       #11: Duct work ...
chris
check out air Handling systems. they are in connecticut.
5/13/22       #12: Duct work ...
Quicktrim
Any HVAC supplier will be able to get spiral pipe and blast gates for you .
Look at the exposed piping in any commercial space , it's spiral duct .
It's actually not bad price wise either.
5/20/22       #13: Duct work ...
Dust collection is not sexy. Certainly not as sexy as a new panel saw or molder, but it is a necessary part of any shop.
Oneida Air has helped me with several collections - they are excellent to deal with.
While not sexy, it is nice to have solid, reliable ductwork to rely upon.
6/17/22       #14: Duct work ...
Rich@Perfectocorp.com Member
Website: http://www.perfectocorp.com
http://www.dustpipe.com/ - Contact Bryan - Very knowledgeable and has helped me designed my system.
    • TradeJobPlacement.com
    • Impact Search and Placement
    • WOODWEB, Inc.
