Subject: Re: Metabo hc 260 2.8 380v cuts out
2/22/24
chinggoss Member
I'm in Ukraine, slowly moving in the direction of setting up a woodworking shop here at our rehab centre.
I just set up a new Metabo hc 260c (380v).
After much mucking around, I believe I have her wired up correctly.
I can use her fine for about 1 minute and then everything shuts down.
If I press the on button, she starts up again full-power, but as soon as I release the on button, she immediately shuts off.
Valuing your experience...
2/26/24       #2: Metabo hc 260 2.8 380v cuts out ...
Mick steele
To troubleshoot the problem more information would be needed. I do not know the machine but you are looking at 2 separate circuits. The high power which feeds the motors 380v and the low power control circuit usually 24v but could be greater. When you press the start button control power is fed to a switch on the motor starter/contactor which pulls in the contacts allowing the high voltage to power up the motor. The machine will stay running until there is a disruption in the control circuit. This could be caused by the heaters/overloads in the motor starter or a loss of control power. If you disconnect the motor wires from the motor starter and then press the start button the machine should power up without the motors running and if it stays in this state then the issue is likely the motor starter, if it does not stay powered the issue is in the control circuit, possibly the power supply. I would think an electrician if available would be the best option
3/8/24       #3: Metabo hc 260 2.8 380v cuts out ...
Dan Gollan
Thanks. I'll hunt up the electrician again. He came, "fixed her", then left. The motor is getting too hot and cutting out still. I can do a couple of boards and that's it.
4/11/24       #4: Metabo hc 260 2.8 380v cuts out ...
Alex Member
Website: https://virmer.com/
It sounds like a possible issue with the electrical wiring or the motor's thermal overload protection. Check the wiring connections and ensure they're secure. Also, verify that the motor is receiving adequate voltage.
    • Impact Search and Placement
    • WOODWEB, Inc.
    • TradeJobPlacement.com
