Subject: Re: Buying a Custom Milling Business
8/22/24
Brian Member
I'm in the due dilligence period to buy a small custom milling company. I'm under an NDA so I can't share a whole lot, but I'm hoping to get a better feel for the industry and a custom mill's position in it. The business does T&G, shiplap, channeling, sanding, resaw, wire brushing, molding, etc.
My main questions are:
Who typically takes custom milling jobs like these? I don't see a whole lot of custom mills out there. Are lumber yards picking up the work?
If you have a custom mill, how many customers do you usually work with? Are they contractors or lumber yards? What are your main focuses as the owner?
Dumping cold water on this or any misc. advice is much appreciated.
8/23/24       #3: Buying a Custom Milling Business ...
Dustin Orth  Member
I own a company that does exactly what you are looking at. Contact me directly and it will be easier to discuss. Dustin Moldings.etc@gmail.com
7/3/25       #4: Buying a Custom Milling Business ...
Steve Member
As someone who's navigated a similar acquisition, I can say custom milling clients are often niche builders, architects, and high-end lumber retailers. It’s relationship-driven and very spec-sensitive. Understanding local demand and machine versatility is crucial. I’d recommend running margin simulations across services—molding vs. T&G, for instance—before finalizing. Focus on cash flow history and repeat business stability.
    • TradeJobPlacement.com
    • WOODWEB, Inc.
    • Impact Search and Placement
