Subject: Re: SMS lock Apps
SMS lock Apps
2/14/23
Trilaen Member
Website: https://trilaen.com/
The Bridgewood planer is a professional-grade wood planer used for creating smooth and even surfaces in a variety of woodworking projects. This planer features a powerful 15 amp motor and a feed rate of up to 36 feet per minute. It has a maximum cutting depth of 3/32 of an inch and a maximum cutting width of 13-1/2 inches. This planer also includes a dust collection port and easy-to-use adjustment knobs for precise planing. It is a great choice for any serious woodworker.
9/30/25       #2: SMS lock Apps ...
Pitchersaki Member
I see it's been a while since you posted, but I’m curious—did you ever settle on how you’re quoting those design jobs now? I’ve been torn between charging flat rate per project or hourly with a cap. Sometimes clients push back, thinking design should be “free” with the build. Anyone found a good way to explain the value of design time without scaring off leads?
9/30/25       #3: SMS lock Apps ...
Headlineosto Member
Funny enough, last month I was using a planner for some old boards I found in the garage. It worked smooth and fast, though I had to tweak it a bit. While waiting for the dust to settle, I ended up sorting a small project list and sent it out using a bulk sms so my crew knew what was next. It saved time and kept everyone in sync without extra calls. Simple and useful.
sms.to
    • TradeJobPlacement.com
    • Impact Search and Placement
    • WOODWEB, Inc.
