NONPaying customers
2/7/15
JERRY DORMINEY  Member
I'm curious about what most shops think about independent tech. What about customers who choose not to pay all their maintenance charges. Even when the tech offers to complete the job at a reduced rate or even free. If you do have an input would you please give the reasons. I may be opening a can of worms here but I have tried to help some customer over the years and have had them either refuse to pay for various reasons or not pay the balance of a job. If you have a negative reply about independent tech please example why.
2/7/15       #2: NONPaying customers ...
mark
It doesn't matter what your trade is, getting paid is part of your job. Since you've had multiple bad experiences, look into your quoting process and the conditions that you are working in to see what you might be able to improve. The goal here is to not work for folks that won't pay. Are you being thrown to the wolves by the manufacturers? Do your clients have a reasonable expectation that their need for tech should be a warranty issue?
I'm my own tech, so I have no good or bad experiences to share. But, I'm my own tech because I think that it's worth my time to know the systems that I depend on inside and out, and I'm not willing to trust that an independent tech will work with the necessary care as they have no skin in the game: not an owner, not a manuf rep. Your situation may, of course, be different.
2/8/15       #3: NONPaying customers ...
Rich Kuban Member
There are a lot of people who are clearly not qualified, charge more than they are worth, do not fix the problem, or have lousy work practices.
Then there are jerks who hire people with no intention of compensating them fairly or fully.
There may be other reasons, but these are probably the most common. You need to find out why you are not getting paid what you charge and resolve the issues. If they are the result of the first set, word will get around. If you can clearly eliminate the first set of possibilities, you need to learn how to avoid working for the second set.
