Bidding
11/19/20
mauricio
What's the best bidding method for residential? By the foot?........cost of material and then add a certain percentage?
11/19/20       #2: Bidding ...
Bidding by a fixed formula is a great way to go bankrupt.
11/20/20       #3: Bidding ...
rescraft
Tree-fiddy per foot.
11/21/20       #4: Bidding ...
D Brown
There are many ways to come up with a price, the cost of materials times whatever typically is not at all consistent.
I have used a simple formula that you can change the values on. so much a running foot for base and uppers X for a raised panel door and Y for a shaker style. I used Red oak as a median price then if they want Cherry add the extra cost or up grade the hardware, so much a foot for finish and installation I use a percentage of the total job. Add all the finished backs and extras. First off is realizing what your costs really are overhead and materials. Good luck.
11/21/20       #5: Bidding ...
Build a spreadsheet, create a row for everything you do that's normal, put each cabinet in a column.
Different species, I use a percentage to modify the total cost of the complete cabinet.
Anything weird, or out of the norm, shoot from the hip like you do anything, pad it a bit, and put it on another page. Link it over to the total formula in your other spreadsheet.
It should be as much a science as possible. For consistency and for fairness.
View higher quality, full size image (1080 X 2280)
    • WOODWEB, Inc.
    • Impact Search and Placement
    • TradeJobPlacement.com
