Worker's Comp Classification Code
11/2/21
Steven
I explained to the ins. agent that we build cabinets, wainscot panels, mantels, and other interior woodwork in a shop, deliver to mostly residential homes, new const. and remodel, and install them, plus on site trim/finish carpentry work.
They want to classify this and quote as code 5437 which seems to only apply to the job site installation work, but not the shop fabrication work.
Can anyone doing similar work tell me what your workers comp code is and if you're sure it covers injuries in the shop and on job sites?
11/2/21       #2: Worker's Comp Classification Code ...
Mark B
We are under 2883 in the shop. No field work. Your rate in the shop should be extremely low compared to field work. You may also want to ask if you need an additional classification for delivery/transport (in-transit coverage).
11/3/21       #3: Worker's Comp Classification Code ...
james e mcgrew  Member
I have WC through a state Home builders Assc. even though I do not do residential.
there portal breaks up my rate for shop (lower) and install (higher) here is an example i filled in so you can see it. our payroll is a lot higher than this
View higher quality, full size image (1569 X 582)
    • TradeJobPlacement.com
    • WOODWEB, Inc.
    • Impact Search and Placement
