Brandt KDF 660
11/8/23
Roger Member
Good afternoon, I bought a Brandt KDF 660 and it showed an error (24 Overcurrent Buffing motor 1) the motors are spinning and are not locked the brakes are on. can anybody help me?
11/12/23       #2: Brandt KDF 660 ...
Bozzy Member
We get a similar error on our Stefani edgebander when long strands of edganding doesn't get sucked up by the dust collection after scraping and end up wrapped around the buffing wheel. We have to take the wheel off, remove the strands and reset the fuse.
5/27/24       #3: Brandt KDF 660 ...
healibis Member
I also encountered the same error on the Stefani edgebander. I proceeded to troubleshoot the problem by removing the wheel, removing the wires and resetting the fuse and everything was working properly again.
1/10/25       #4: Brandt KDF 660 ...
moto x3m
Website: https://motox3m-game.com/
I am also getting the same error. It is so annoying.
4/16/25       #5: Brandt KDF 660 ...
io games Member
When the dust collector on our Stefani edgebander doesn't catch lengthy strands of edgebanding after scraping, they wind up entangled around the buffing wheel, causing a similar issue. The wheel needs to be removed, the strands must be removed, and the fuse must be reset.
    • TradeJobPlacement.com
    • WOODWEB, Inc.
    • Impact Search and Placement
