Seeking Recommendations for Reliable Industrial Woodworking Services
5/20/25
Ron Chamberlain
Hi everyone,
I'm looking for recommendations or referrals for professional or industrial woodworking services. We have an upcoming project that requires custom millwork, CNC machining, and large-volume hardwood fabrication, and we're looking for a company or shop with proven experience in handling precision work at scale.
Ideally, we're after a team that understands the demands of industrial-grade output—tight tolerances, durable finishes, and efficient turnaround times. If you’ve worked with a shop that consistently delivers high-quality results or if you offer these services yourself, I’d appreciate any leads, insights, or contact info.
Thanks in advance for your help!
7/20/25       #3: Seeking Recommendations for Reliabl ...
bitlife Member
We’ve had great results—they handle CNC work and large-volume hardwood projects with precision and quick turnaround. Highly recommend reaching out to them.
7/25/25       #4: Seeking Recommendations for Reliabl ...
Vera Member
I am an exporter of plywood from Vietnam. My factory can manufacture plywood according to your requirements. Ensuring standards with certificates such as FSC, EPA, CARB P2, and ISO 9001:2015. I
8/26/25       #5: Seeking Recommendations for Reliabl ...
Daniel French Member
We recently went through a similar search for dependable industrial woodworking partners, and the biggest challenge was balancing quality with turnaround. What helped us was focusing on shops with CNC capacity and documented quality standards (like ISO or FSC). Also, don't hesitate to ask for sample runs. A good vendor won't hesitate to prove consistency before signing on for a larger project.
    • TradeJobPlacement.com
    • WOODWEB, Inc.
    • Impact Search and Placement
