What’s the Most Common Mistake in Cabinetmaking?
10/28/26
furnigence Member
Website: http://www.furnigence.com/
Hi everyone,
For those working in cabinetmaking, what mistake causes the most trouble in your projects? Is it measuring, cutting, fitting hardware, or something else?
I’m interested in learning how different shops deal with these problems and avoid rework.
Thanks for sharing your experience!
— FURNiGENCE | Millwork Drafting & Cabinetry Engineering
10/28/26       #2: What’s the Most Common Mistake in C ...
D Brown
I would say that accurate measurements and a layout that is correct matters.
10/29/26       #3: What’s the Most Common Mistake in C ...
The most common mistake in smaller shops is not charging enough. What you do after that is less important.
10/29/26       #4: What’s the Most Common Mistake in C ...
Mitch Suber Member
I agree with accurate measuring and knowing how to measure so the finished products fit and perform as expected. Under pricing is definitely a big mistake, and not pricing to cover mistakes. Because I'm pretty sure those mistakes will happen.
    • Impact Search and Placement
    • TradeJobPlacement.com
    • WOODWEB, Inc.
