Subject: Re: Plastic casework
Plastic casework
4/27/15
CHRIS SCOTT Member
Website: http://www.scottscabinet.com
We are currently doing a job that calls for cabinets made from solid plastic. The product we are using is called King plastics. Has anyone here used this product or have any advice on cutting on CNC ect?
4/28/15       #2: Plastic casework ...
james mcgrew Member
Cutting some UMHV for a test fit prototype this AM I will try and video it for you,, this stuff cuts nice
4/28/15       #3: Plastic casework ...
Rich Kuban  Member
Website: closetexperts.com
If you are referring to King Starboard, I did one job with it and it was a bear. They claim standard woodworking tools but it was rough to machine because it wants to melt and gum up bits or blades. And if you think melamine is heavy, well wait to pick up a piece of this stuff. If you screw boxes together you will need more fasteners than normal due to the weight. Hope this helps and good luck!
4/28/15       #4: Plastic casework ...
Rick W
I've used a lot of King Starboard LT (lite).
It's lighter than melamine and cuts well with regular wood-working machinery.
For cuts on the table saw, I use a blade designed for cutting plexi.On the CNC, I use a 3/8" 0-flute bit, 18000 rpm @ 180 IPM. It probably could be cut at a faster speed, but that's what I use and it gives a good cut.
Rick W
4/29/15       #5: Plastic casework ...
Ed
It is heavy, I think they named it starboard because you see stars after lifting the sheet on to the saw. I have had about 40 sheets through my shop and noticed no problems cutting, I sand the edges with abranet discs, to remove cut marks. Usually fasten with confirmats and plastic biscuits to allign joints. Tried clamex fasteners on one job, and found cutting with the Lamello zeta P-2 dangerous unless the tool was braced on the side, it would throw it self out otherwise.
Only consider that option for knock down rta construction. Drilling system holes with line borer required cleaning off bits between cycles, as any material left on bits would melt into next hole. Maybe someone coud suggest a better bit suited for plastic.
I bought the Forrest plastic blade and did not notice any improvemnt over their regular wood blade. The texture on the face holds dirt, I wish they would make a panel without the texture. Maybe they do , I was not aware of the Lt version, so thanks for that tip. One last thing, make sure you are grounded when removing protective coating or you will get a static jolt, I hold onto the saw when peeling the coating off, discharging the static off to ground.
Hope this helps.
Ed
4/29/15       #6: Plastic casework ...
james mcgrew Member
Use lower rpms like 10-14 k speeds at 400 + this was done with .25 up spirals 2 flute but "O" flute will work better.
I cut .1875 holes, pocketed and profile cut this yesterday,, Not the chips on the table.
this was Uhmv (UHMW Polymer (plastic) is a linear polyethylene with a molecular weight in the range of 3,000,000 to 6,000,000. This value represents the "average molecular weight". Therefore UHMW is 10 times heavier than regular high density polyethylene.)
and starboard is similar
View higher quality, full size image (2448 X 1836)
    Lamello
