Subject: Re: Vertical partition euro cabinet
5/3/15
Bob Member
Any body use a single vertical partition(3/4") to divide a cabinet and then mount tandems and hinge plates on each side(at same height)? I have been doubling up the partitions so far. In theory the screws would run into another but a test piece I did seems to be acceptable(slight angle of screw head).
5/3/15       #2: Vertical partition euro cabinet ...
Ed
If you are using system holes, just use shorter screws, 10.5mm or use twin application screws.
Ed
5/3/15       #3: Vertical partition euro cabinet ...
Bob Member
Not using system holes.
5/3/15       #4: Vertical partition euro cabinet ...
Ed
The tandem slides have 2 rows of screw holes, just alternate.
Ed
5/3/15       #5: Vertical partition euro cabinet ...
JeffD
Drill the holes in the center partition through and then use male/female screw/connectors to mount the slides/hinges. Blum is pretty good about handling just about any situation there slides get used in.
Oh and stop using screws to attach your slides, its bad practice. Get yourself a box of euro screws and a 5mm drill bit….you and your clients will be much happier for it.
good luck,
JeffD
5/3/15       #6: Vertical partition euro cabinet ...
Bob Member
Thanks so much for the help.
Now have to weigh using those methods and my double partition to see which is more cost effective.
5/4/15       #7: Vertical partition euro cabinet ...
Leo G
Jeff, why would my clients be happier that I don't use a #6 screw? I've never had a screw come out. 5mm have their place if you are using the system.
Sex bolts (Blum 612.2010) are what you use to put hinge plates on a single thickness partition. For slides you just alternate screw hole positions. Use half cranked hinges and you're golden.
5/4/15       #9: Vertical partition euro cabinet ...
JeffD
Leo, normal #6 hardware screws loosen over time, especially in hinges. Just because you haven't heard of them loosening does't mean they don't:) I've gone back to several jobs for additional work and found loose hinges on my previous work. Nobody ever complains, in fact when I point out it's loose I usually get something to the effect of "oh yeah, I've been meaning to tighten those". And I've found the same thing happen on factory kitchens as well.
Euro screws on the other hand don't seem to loosen up over time. So I'd rather go with what I perceive as the better quality method, especially when there's virtually no cost difference.
JeffD
5/4/15       #10: Vertical partition euro cabinet ...
Leo G
Never had a problem with drawers. Most of my cabinets are inset so the FF plates get screwed to maple, so they don't come out. I use only 3/4" screws unless I can't.
Still waiting for the loose screw to show up in one of my jobs.
On the other hand, using ball bearing side mounted slides with the 3/8" screws I've had nearly all of those need tightening after a year. Which is on of the reasons I switched and stayed with the Blum undermounts.
