Subject: Re: Heat shield from oven to cabinet ?
8/6/15
Richard Goodman  Member
Website: lagunabamboo.com
I have a project where the home owner would like me to incorporate a way to block the heat from the slide in range to the cabinet next to it. ( Trash unit ) Any help would be appreciated.
Thanks,
Richard - Laguna Bamboo
8/6/15       #2: Heat shield from oven to cabinet ? ...
Bruno
Create a space or pocket in side that trash cabinet and fill it with a high R-value insulation. If you can't try to incorporate some sort of decorative spacer on both sides of the stove and fill that with insulation. stonewool insulation is practically fire proof from what I hear. Best I can think of.
8/6/15       #3: Heat shield from oven to cabinet ? ...
Seems redundant? The stove are designed to go next to cabinets.
I have never done this.
8/6/15       #4: Heat shield from oven to cabinet ? ...
Bruno
Totally agree with Pat 100%, but if costumer still insists, do it and charge for it!
8/6/15       #5: Heat shield from oven to cabinet ? ...
Alan F.
Use ceramic fiber board, allows MW to be closer to stove, The guys in my link generally don't sell single sheets, there are other vendors that sell single sheets.
We do ceramic fiber and place metal over the board, meets code
"clearance to combustible is 24 in. (not applicable when an electrically heated warming tray is provided on the back guard) when the bottom of the wood or metal cabinet is protected by not less than 1/4 in. flame retardant millboard covered with not less than No. 28 MSG sheet steel, 0.015 in. stainless steel, 0.024 in. aluminum or 0.020 in. copper."
Ceram Source Ceramic Fiber
8/10/15       #6: Heat shield from oven to cabinet ? ...
Thanks for everyones response. The solution for this project is to go with a ceramic fiber board as Alan suggested.
I thought you might like to know that the client measured inside temp of his existing cabinet, that is next to a slide in range and it was 155 degrees. He definitely has a valid point that garbage heated to that temperature would not be a welcomed addition to his new kitchen, although my first reaction was similar to those who posted here.
I 'm thankful that when my client asked me to find a solution , I felt confident I could go to this forum and get the help I needed.
The client is happy and I am happy to share what I have learned with all of you.
Best Regards, Richard - Laguna Bamboo
