Subject: Re: tip-out slides
tip-out slides
10/5/15
Joe Biden 2016
I've got a residential job where I used the Blum 563H undermounts for a drawer bank. The customer now wants the "tip-out" or push to open slides. Apparently, the tip-out slides Blum makes don't have the soft-close feature. I would like a drop-in replacement. I saw that you can get a brand called King Slide from Rockler that are both tip-out and soft close.
Anybody have a recommendation from one they've used?
10/5/15       #2: tip-out slides ...
David  Member
Website: dtwoodworker.houzz.com
The blum slide for a 21 inch drawer with tip- on is a 562 H 5330 C for 1/2" - 5/8" side thickness. You also need the tip on set which is T55. 7150 s. The locking devices are T51. 1700. 04. You are right about the slide not having soft close. But it will go right into place with the same holes as the 563h except the locking device has one different hole. To get tip on with soft close you have to install a servo drive. I have used both, the tip on with servo drive is extremely smooth, while the spring loaded tip on is OK but not as nice as the servo drive version. I have not used the King slide, but have not heard good reviews about it. Word on the street is that blum will have a tip on with soft close and no servo drive sometime in 2016.
10/6/15       #4: tip-out slides ...
The Salice Unica is a non-electronic self-opening, soft close under mount drawer slide. Please see the link below for a brief video.
10/6/15       #5: tip-out slides ...
Joe Biden 2016
That's interesting. I called my Hafele rep and he told me Salice didn't have this type of slide.
He's a nice guy, so please don't fire him.
10/6/15       #6: tip-out slides ...
Joe,
It's a relatively new item so all of the Hafele guys may not yet be onboard. Also, I tried without success to put a video here...I will try again later. What part of the country are you located? Don't wory, we won't fire Hafele. :)
    Lamello
