Subject: Re: p-lam on drawer fronts
2/19/16
Michael  Member
Just to verify...when building casework using wood grain patterned plastic laminate isn't the correct method to run the grain in the vertical direction on the drawer fronts?
2/19/16       #2: p-lam on drawer fronts ...
Family Man
Depends on how it is spec'd. I would say vertical grain more common, but these past few years have seen an uptick in horizontal. Best to check with the client.
2/19/16       #3: p-lam on drawer fronts ...
Michael  Member
Thanks.
I guess in most cases it should run the same direction as the grain on the doors??? After looking at some web pics I noticed there were some running horizontal but so was the grain on the doors.
2/20/16       #4: p-lam on drawer fronts ...
james mcgrew Member
I sure hope you have some specs, residential or commercial ?
Remember Specs Trump plans (Pun Accidental)
View higher quality, full size image (619 X 159)
2/20/16       #5: p-lam on drawer fronts ...
Michael  Member
Commercial (school)
2/20/16       #6: p-lam on drawer fronts ...
james mcgrew Member
The specs should tell you grade Economy, custom And I doubt premium.
can you post the spec section
2/22/16       #7: p-lam on drawer fronts ...
Michael  Member
Went through the specs again this morning and found that they are requesting premium grade. Thanks for the help!
2/22/16       #8: p-lam on drawer fronts ...
james mcgrew Member
If that is the case I would google the AWI standards, and Join the AWI in the long run you are gonna want to know this.
Premium can call for some things beyond a grain direction and with laminate make sure it matches verticle and horizontal
Depending on architects knowledge of AWI specs You may have to plam the interior of the doors and drawers.
I always read the specs before looking at plans during bidding
2/22/16       #9: p-lam on drawer fronts ...
Michael  Member
Will definitely do that. Thanks again for the info
    Lamello
