Subject: Re: Porter Cable 310 trimmer help
4/23/16
Ed Milne Member
I am looking for a bit of help. I am searching for a particular tool, the spanner wrench used to tighten the retainer nut on the shaft of a PC 310 series trim router. the nut itself is PC part# 844643. I have had no luck searching for a specific tool, or in finding a spanner wrench with the proper size pins/spacing.
Any help/advice would be appreciated. TYIA
4/23/16       #2: Porter Cable 310 trimmer help ...
Richard Member
Go to the link and look at fig 224. It says open end wrench.
http://www.1800toolrepair.com/tool-repair-parts/porter-cable/routerrota
ry-tool/310/310type2
If that;s no help you might try emailing "'Pat Warner - The Router Man " and ask him where you might find one.
http://www.patwarner.com/
4/23/16       #3: Porter Cable 310 trimmer help ...
Ed Milne Member
Thanks for the speedy reply. The wrench you indicate is one of the pair that comes with the unit for changing bits, but I will be emailing Pat per your suggestion.
4/23/16       #4: Porter Cable 310 trimmer help ...
Mark
I had the same problem as you-
I ended up grinding a flat wrench from some other brand a little wider to fit the nut and use the one wrench I had for the shaft.
FYI, the PC 7301 uses the same wrench,nut & collet but I couldn't get one at the time; out of stock, N/A or some such crap.
4/23/16       #5: Porter Cable 310 trimmer help ...
Ed Milne Member
OK, I realized after the replies I got so far that my initial description was not clear enough.
The retainer nut I am looking for a spanner wrench for is the flat disc of metal with two holes in it on that you see when looking at the bottom of a 310 trimmer. It threads onto the shaft and hold the motor assembly into the body proper.
4/23/16       #6: Porter Cable 310 trimmer help ...
Mark
Oohhhh.......
Well, good luck with that. ;-)
I didn't read your question thoroughly, either.
There are a few pin spanners out there that have different size pins to put in the wrench, but they seemed to start at about $30 + S&H . ( I have a Proto pin spanner and just tried it on my router; no go, pins too big)
You could make a wrench pretty quick to get it apart. I'd suggest a couple of spring pins from the hardware store and a piece of hardwood or possibly phenolic, acrylic, or even some solid surface material like Corian for the wrench. Unless you're replacing bearings in a bunch o routers, might be the most cost effective route.
Good luck, let us know how you make out.
4/24/16       #7: Porter Cable 310 trimmer help ...
KD
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3AAdjustable%20Spann
er%20Wrenches
4/25/16       #8: Porter Cable 310 trimmer help ...
eddie
Northern Tool sells an adjustable spanner wrench. I have one it works well. As long as you get the thumb screw tight after adjusting.
