Subject: Re: Mixer/appliance lift
8/10/16
Tony
I recently installed a mixer lift in a kitchen island we did. I have installed these before (rev-a-shelf) and although my customers have seemed to like them, I never have. The one we just installed was specifically for the customer's espresso machine, which weighs about 65 lbs. The weight makes the mixer lift more like a big swing. It will not stay in a closed/back position, but swings down and forward. I realize (too late) that the weight rating of 80lbs was just static weight support, and the functional weight limit is only 60lbs. I am looking for a mechanism that will be able to handle this situation, raising the relatively heavy appliance up to a workable height. I have looked at a few options, and will more today, but I am looking for suggestions from those who have actually used them. My hardware supplier carries a model with soft-close, and I'm not sure right now which brand/model specifically. Thanks for your help.
8/11/16       #3: Mixer/appliance lift ...
Tony
I really need a solution for this. The soft close won't work either. Surely there has to be a mechanism that would function with that weight. Any suggestions appreciated. I've even thought about re-configuring the springs myself?
8/11/16       #4: Mixer/appliance lift ...
eddie
Call rev-a-shelf directly or your rev-a-shelf rep. I am sure someone else has had this or a similar issue. Most they can say is "we can't help you".
