Subject: Re: 1mm White PVC Edgeband
4/15/17
TL
Decent source for this? We've been getting it from Richelieu for years, but have been increasingly less satisfied with the quality.
Looking for alternative sources. Thanks.
4/16/17       #3: 1mm White PVC Edgeband ...
james e mcgrew Member
Charter industries, framatech, edgeco,
4/16/17       #4: 1mm White PVC Edgeband ...
TL
Thanks, I should say alternate/economical source. We go through a fair amount of this and I've found that the price can vary widely.
4/16/17       #5: 1mm White PVC Edgeband ...
Rich Kuban Member
You might want to post what part of the country you are in, since freight is a significant factor in banding cost if not bought with free shipping. I bought 1 MM white PVC from these people located north of Chicago.
http://pri-edgebanding.com/
4/16/17       #6: 1mm White PVC Edgeband ...
TL
Located in Northeast. Thanks for the link.
4/22/17       #7: 1mm White PVC Edgeband ...
bob
DC Distributing
800-727-0917
in PA
edgebanding is all they do
4/22/17       #8: 1mm White PVC Edgeband ...
TL
As Rich suggeted, it's looking as though shipping may be a deciding factor. Do any of these companies offer free, or a flat cost for shipping. We typically order 15 rolls at a time.
4/23/17       #9: 1mm White PVC Edgeband ...
Derrek
Edgeco is by far the cheapest. Im in California and buy from them. They have good price breaks for volume, quality is very good.
Side note, make sure you rotate your stock. We had a few rolls at the bottom of the stack that hadnt been used and was over 1 year old qnd had become brittle and not usable.
6/4/26       #10: 1mm White PVC Edgeband ...
Daniel Ni
Website: https://www.jymat.com/
For 1 mm white PVC, I would compare the landed cost per roll, not only the quoted roll price. Freight can easily erase the saving when the order is only 10-20 rolls.
A few quality points worth checking before switching source:
1. Fresh stock. PVC banding that has been stored too long can get brittle, especially on the outer wraps.
2. Thickness and width tolerance. With 1 mm white, small variation shows up quickly on trimming and radius work.
3. Color/gloss consistency between rolls. White is unforgiving if rolls are from different batches.
4. Primer/back treatment and adhesion with your hot-melt glue. Ask for a short sample roll and run it on the same bander/glue before buying volume.
If the shop needs urgent small quantities, a regional supplier often wins because of freight. If you can combine colors/specs or keep regular stock, factory-direct importing can be more economical. I manufacture PVC edgebanding and hot-melt adhesive from the supplier side, so if import timing works for you, 1 mm white PVC and sample matching are straightforward.
    Lamello
