Subject: Re: Raised panel shaper passes
11/26/18
Willem Martins  Member
Website: thelastwoodworker.com
7.5hp shaper 1hp power feeder, 6" diameter raised panel cutter.
How many passes for a cut and what RPM would you run this for 7/8" Cherry.
11/26/18       #2: Raised panel shaper passes ...
Dom
1 Pass 6000 rpm. Ends first of course.
11/26/18       #3: Raised panel shaper passes ...
MarkB Member
One here also
11/26/18       #4: Raised panel shaper passes ...
1 pass. Those are going to be heavy doors with a 7/8" panel.
11/26/18       #5: Raised panel shaper passes ...
The 7/8" is what we are comfortably getting out of this lot of 4/4 rough sawn Cherry. You think we should make more saw-dust and go down another 1/8"?
Customer likes thicker, but we normally do the panels thinner and the stiles and rails 3/4"
This is a furniture grade kitchen.
11/26/18       #6: Raised panel shaper passes ...
Edi Silva  Member
Website: silvawoodworking.com
1 pass at 5600 rpm here.
11/26/18       #7: Raised panel shaper passes ...
Jim Herron
Single pass.
11/27/18       #8: Raised panel shaper passes ...
1 pass.
I would slow the power feed down to 14 or 15 fpm. Whatever your feeder speeds you have.
How fast the cutter is moving is only one variable.
11/27/18       #9: Raised panel shaper passes ...
Joe Calhoon  Member
Always one pass for us, usually 6000 rpm. We have a big entry door panel head that runs at 4500.
With cherry sometimes we cut the ends first at a slower feed rate, then run with the grain at a faster feed to eliminate burning.
11/28/18       #10: Raised panel shaper passes ...
Larry Schweitzer
One pass, 6000rpm, adjust feed to suite results. Too slow and you will burnish, burn &/or dull too quickly.
11/30/18       #11: Raised panel shaper passes ...
david zaret Member
yep, one pass, moderate speed on the feeder to prevent burning the cherry. walnut, i slow it down with no issues.
12/3/18       #12: Raised panel shaper passes ...
Dave
I always do 2
12/8/18       #13: Raised panel shaper passes ...
I ended up with a Freeborn 6” cutter, 8,000 rpm, slow feed on the border of burning and tearout. The cuts are nice and clean.
