Subject: Re: Range Hood Cabinet Duct Access
12/11/18
Steven
I have a customer with a range hood cabinet enclosure that has two doors on the front that open to the duct work. They don't like this look and want me to removed the doors, fill in the openings and Bondo the seams(cabinets are getting re painted) to create a flush face.
I have seen range hood cabinets with no doors or access panel to the inside, but I would think that would be just for the kind that uses charcoal filters and doesn't vent outside.
They are getting a new insert range hood, and initially I was thinking the installer will need access through these doors to hook up the duct after inserting the hood into the bottom opening, but then I thought maybe they could use some flexible ducting to make the connections before inserting it. Is that possible?
12/11/18       #2: Range Hood Cabinet Duct Access ...
Can't you knock the face frame off and replace it with a panel?
12/11/18       #3: Range Hood Cabinet Duct Access ...
Steven
Pat, not really. I didn't mean the hood enclosure was actually a square cabinet box; this is a custom hood. The face that the doors are on angles out from a 16" deep cornice to a 22" base so there is an inside miter where it joins with the cornice and outside miter where it joins the base. Just trying to determine whether that access is necessary so I can let my customer know if what they're wanting is possible or not.
12/12/18       #4: Range Hood Cabinet Duct Access ...
james e mcgrew Member
There is a reason access existed in the first place IE: maybe access to the top of the unit for maint for example, i would find what that is first, Pat is right if it had doors it can have a panel
12/12/18       #5: Range Hood Cabinet Duct Access ...
Steven
Thanks for the replies. The doors seem to have been incorporated into the design for aesthetics and maybe to make the installer's job easier. There's nothing behind them that could be maintained other than the connection to the exhaust duct. I was able to get in touch with the installer for the new insert hood and was told that he doesn't have to have access through the face of the hood enclosure to hook up the duct work when installing, only that it would make it easier.
12/12/18       #6: Range Hood Cabinet Duct Access ...
D Brown
You may also be able to use the @3" X10" rectangular exhaust located to the rear of most hoods. They don't take up space in the middle and look a bit better.
12/14/18       #7: Range Hood Cabinet Duct Access ...
The only flaw is if the inspector (if there is one) wants to inspect the duct connection.
    Lamello
