Subject: Re: Wall backing
Wall backing
2/26/19
Greg Jenkins Member
Just got back from a job where the contractor installed metal "backing" for me to install my upper cabinets. I just need a sanity check here. I believe it was 1/16" thick or more. My guess is that some dummy confused the metal plates used to protect plumbing and electrical with "backing" for cabinets. None of my drill bits would penetrate it. Nor should they have to.
Just want to get some corroboration before I lay into someone without reason.
2/26/19       #2: Wall backing ...
rescraft
Since it won't be seen, do some exploratory surgery on the drywall, in the area you would place the fastener.
2/26/19       #3: Wall backing ...
Greg Jenkins Member
I did. It was 1/16" or so thick metal.
2/26/19       #4: Wall backing ...
At that point use self drilling/tapping metal screws. 1/16" thick is good enough to get a nice bite.
Whoever did this should be yelled at for quite some time.
2/27/19       #5: Wall backing ...
Hen Bob Member
We supply to a contractor that is remodeling a retirement village. All of it is steel framing with a 6" wide piece of 1/16" steel running horizontally for backing. They use #10 self tapping screws.
2/27/19       #6: Wall backing ...
Michael
This is common in commercial jobs where metal studs are used but never seen it used in wood framing. We only do commercial (school) casework and these are the screws we use to install our cabinets...
http://www.panamericanscrew.com/default.aspx?page=item%20detail&
;itemcode=BTXF10212D3Z-2
2/28/19       #7: Wall backing ...
Larry Schweitzer
It is common in our area and I think specified by the architect. Self drilling sheet metal screws will do fine. The ones that have a drill bit like tip.
2/28/19       #8: Wall backing ...
Greg Jenkins
I was back today for a couple pickup items. Bought the self-tapping screws, and they still didn't bite.
Apparently it's an earthquake code.
I do wonder about the gauge of the metal that was used in this case. If self-tapping screws won't bite, might be too thick.
2/28/19       #9: Wall backing ...
Predrill with a standard metal drill bit slightly smaller than what size the self tape screw will drill.
If you bought screws that just have a point on them, they won't cut it. You need the screw with the drill tip. The only time these don't work is if the drill tip is shorter than the thickness of the steel.
