Subject: Re: Stainless steel softclose hinges
3/14/19
Kevin Member
Wondering if anyone can recommend a SS soft close hinge. Looking for full overlay. A google search found some, but no manufacturers I had heard of. Sugatsune looked promising but I don't believe they come in soft close. Thanks.
3/15/19       #2: Stainless steel softclose hinges ...
Hi Kevin,
Your search can end here.
The Sugatsune is, to my knowledge the only stainless steel concealed (European style) hinge on the market and, you are correct, it is not available in soft close.
This is a common question for use in outdoor kitchens and for MRI rooms. If your application is for an MRI room, you should check the specs with Sugatsune. I don't believe their SS qualifies.
You could always add a Smove damper to make the door soft close.
Best of luck,
Dennis
3/15/19       #3: Stainless steel softclose hinges ...
Alan F. Member
My first question is do these hinges need to be stainless because of where they are being used?
A lot "designers" specify stainless steel hinges thinking they will match the door hardware or that the nickel finish is stainless steel.
We did a large job a few years ago where they marked up the shop drawings to use stainless steel hinges, slides, shelf pins all to match the pulls which was different from the specification so they went through the roof on the change order.
I am doing a job now where the carbon steel is to have a stainless steel finish applied.
Sugatsune can be used in a MRI room as long as the specifier understands and approves that the SS parts are fabricated with carbon steel tooling and there is transference to the stainless steel parts.
Modern MRI machines get the magnets tuned to the room and that small amount of carbon is generally okay.
Sugatsune has a disclaimer letter that needs to be approved in this instance.
A-
3/18/19       #4: Stainless steel softclose hinges ...
Doug
Kevin,
I remembered reading your post a few days ago and saw this on a distributors counter today.
https://www.richelieu.com/us/en/category/hinges-slides-and-opening-systems/hinges-
and-accessories/european-style-hinges/series-hinges/rcs-series-clip-on/hinges-rcs
/rcs-105-stainless-steel-hinge/1189032/sku-RCS36050040170
It is a Richelieu 304ss soft close european hinge.
3/20/19       #5: Stainless steel softclose hinges ...
Kevin Member
Thanks Doug. That looks like the ticket. I ordered a pair from a different manufacturer to try as well. Never heard of them, FYRONDY. Richelieu looks more promising. Thanks again.
    Lamello
