Subject: Re: Door opening restrictor
3/23/19
Jon Member
We just installed a frameless job and have a couple doors that the handles are touching adjacent panels when they are fully opened.
We usually use the 86 deg. restrictors, but due to the handles being a little taller (1 1/4"), the 86 deg. is not quite enough.
I am looking for a hinge that would match the Blum boring pattern that the opening angle could be restricted slightly more than the 86 deg.
3/23/19       #2: Door opening restrictor ...
TonyF
Jon:
You might try this Blum angle plate, and in conjunction with the 86 degree limiting clips, might be just enough for your application.
Hope I understood your situation correctly.
TonyF
Blum Angle Plate
3/23/19       #3: Door opening restrictor ...
Jon Member
Thanks, I bet that will do it. I just need a few degrees.
