Subject: Re: 3/4 overlay face frame hinge
4/30/19
Perry Vavra Member
Looking for preferably a blum, face frame, 3/4 overlay hinge that is 2 piece but not having any luck. Tried some generic 5/8 overlay with 6mm tab distance but it is maxed out of adjustment at 3/4 overlay. Want to avoid compact on this job. Does any one know if a hinge like that is available in soft close?
5/1/19       #2: 3/4 overlay face frame hinge ...
Hi Perry,
This is an easy application for Salice soft close hinges.
The attached drawing shows an 18mm overlay with an edge bore distance of 4mm. You could do this and adjust out 1mm or you could use a 5mm edge bore and have a resulting 19mm (3/4”) overlay. If you chose option 2, you will still have 1.5mm of outward adjustment for fine-tuning in the field.
Also, with Salice, you could also use a 6mm bore distance and have a 20mm overlay (13/16") with all adjustments still available. (Adjustments: +1.5mm, - 3.5mm)
Items:
C7R6AE9 110 degree, full overlay, soft close with dowels
BAU3R19 1mm face frame mounting plate (with 2 cam adjustments)
Let me know if you would like samples for a mock-up.
Best of luck,
Dennis
5/1/19       #3: 3/4 overlay face frame hinge ...
james e mcgrew  Member
Salice is a good hinge, we are a blum end user due to a loyalty to a distributor.
that said we use the Blum full overlay face frame plate and Inserta clip top hinge as our standard
Blum Clip-Top
5/1/19       #4: 3/4 overlay face frame hinge ...
Ryan
Blum
110+ hinge
0mm plate
6mm bore distance
5/3/19       #5: 3/4 overlay face frame hinge ...
Redneck
Check out Grass hinges....
