Subject: Re: notching drawers for undermounts
5/4/19
keith farr
We have always used a sabre saw to cut notches for undermount guides was wondering some suggestions for doing this without buying a ready made drawer box nothing machine Thanks for any help
5/4/19       #2: notching drawers for undermounts ...
D Brown
One way is to cut the back down and not have any of the rear drawer member below the drawer bottom.no slot is needed .
5/4/19       #3: notching drawers for undermounts ...
I made a router jig.
I use 2 routers, the big router has a 1/2" flush bit in it and the jig forms the notch width and the bottom and the side of the drawer is where the bearing glides to form the rest of the notch.
I hog out the majority of the material with the 1/2" bit and then I use a small router with a 1/4" flush cut bit in it and "square" out the corners.
The 1/8" radius corners don't interfere with the operation of the slide at all. I make the width of the slot about 1/16" wider to make sure it doesn't. Takes about 45 seconds to do a drawer.
5/4/19       #4: notching drawers for undermounts ...
Dustin orth
Attached is a video on how I notch drawers. Did this a few years ago. I now use a small shaper dedicated for this.
5/4/19       #5: notching drawers for undermounts ...
Harold morantz
Website: http://morantz Cabinets.com
We use the first persons method. Drawers have 3/4” front and back and 1/2” sides and bottom, all prefinished plywood left overs from cabinet boxes. Front and back are 1” shorter than sides pocket holed into sides. Bottom is shot into front and back with 1.5” Brad nails and picket holes to 1/2” sides. No need for any notching . Our base and upper cabinets are 3/4” with 1/2” nailed on and screwed backs overlapping so they nterior of upper is 11.875. Plenty of scraps left for drawer parts except for large drawer bottoms, we use an optimization program called The Itemizer amd liad all
Parts to maximize sheet yield and do not have to wait for drawer boxes from any vendor. All parts are cut on slider, bored and handed and one guy is building boxes and installing slides while another is assembling boxes. Fast and easy fir a non CNC shop, euro legs are also mounted while base box is being assembled as well as lazy Susan or hinge plates.,
5/6/19       #6: notching drawers for undermounts ...
Ryan
If we build a box which is almost never because if hard to make them for the cost of solid wood dovetail boxes from hardware resources. This way you and your guys can do other stuff like building cabinet boxes that makes you more money. When we did we cut the back short and build the box then slide the bottom in and staple it to the back of the box. When we build boxes we cut them on the cnc which would be easy to notch but its easier to build them this way. Boxes are also made of 1/2" prefinshed baltic birch.
5/6/19       #7: notching drawers for undermounts ...
Mark B
I don't do a high volume of boxes, but when I do I take two passes with a 3/4" dado blade on the TS.
5/7/19       #8: notching drawers for undermounts ...
eric z
#5 harold
i like your idea for speed and simplicity but, assuming you are using undermount blum/ grass/similar, how do you mount the clips for the slides without the lip to reference against on the bottom front edge ?
5/7/19       #9: notching drawers for undermounts ...
Ryan
Eric that is why we still leave the front the same height as the sides and only cut the back short.
5/10/19       #10: notching drawers for undermounts ...
I bought a delta shaper at an auction for $200, and had two dado sets bored to fit the spindle. Slowed it down with a pulley off of McMaster-Carr.
A dedicated actual drawer notcher that drills the hole as well is on my short list.
