Subject: Re: Edgebander
Edgebander
5/13/19
Brett Nock Member
Hi I am looking at buying a Holzher 1303 edgebander. 2007. Anything I should be aware of.
Thanks Brett
http://brett@nockonwoodinc.com
5/13/19       #2: Edgebander ...
Rob Young  Member
Website: nutekmachinery.com
Is the machine available for you to inspect and run parts through? If so run a variety of edge thicknesses through the machine and evaluate the quality of the finished part and the difficulty level of switching back and forth between different edge thicknesses.
The extruded glue system doesn't work well filling the gaps on the edge of particle board and plywood resulting in telegraphing of the gaps through thin PVC edging resulting in a pockmark looking edge. If you run thin PVC regularly you would be better off with a glue pot machine.
5/13/19       #3: Edgebander ...
Brett Nock Member
Yes I can see the machine run. I do most veneer tapes. Would you say it is a good machine as in make
Thanks Brett
5/13/19       #4: Edgebander ...
Collin Parker  Member
Website: heritagewoodwright.com
holzher is one of the top edgebander brands, however a used edgebander could be a scary thing depending on the previous owner's care and the model. like others said, id suggest bringing a variety of your own parts and have them run them as a demo. some other things to look out for, do any of your operations hit the copy wheels? are you paying <.25-.50 on the dollar? is it still in operation? all things to consider
5/13/19       #5: Edgebander ...
Brett Nock Member
Thanks for the help.
5/14/19       #6: Edgebander ...
Rob Young  Member
Brett,
I'm assuming the specific model you are looking at is the 1303 UNO. This model has a single motor end trimmer that utilizes 7 different valves to end trim the leading and trailing edges of the panel. It can be a nightmare. Even the slightest contamination in the compressed air system can cause valve failure and timing issues. The top and bottom trimming motors are light weight as well, but this may not affect you if you are only running veneer through the machine. I had a customer that did quite a bit of high-pressure laminate and it was simply too much for this model to handle.
I have customers with reliable edgebanders that purchase new and are looking for a home for the edgebanders they are replacing. I'd be more than happy to put you in contact with them. Feel free to message me or go to my website if you would like to get my contact phone number.
5/14/19       #7: Edgebander ...
That is a really light duty bander and getting pretty old. Many parts are off the shelf but many are not and availability can be a problem.
5/16/19       #8: Edgebander ...
Jay Member
Brett, I like Holz-Her banders, and have owned a few of them as well as quality glue pot machines. If they are set up and operating correctly, aside from warm up time needed to feeding the first part, there is no real difference in output product. This particular model with the single end trim however, if you just want to replace a hand iron, sure, if you have real production needs, I'd avoid it and go with one of the more robust production machines. The one trimmer unit was not a real success for them.
As another poster mentioned, used banders, regardless of brand can be a bit of a crap shoot depending on how it was cared for and how many hours are on it.... I would not avoid them, just do extensive due diligence, and if you have never owned one, get a good independent tech to inspect it or give you it's real history. It will be the best money spent.
