Subject: Re: Biesse Akron 645, presser not working correctly
11/26/19
Blendi Ymeri Member
Hi,
I own an edgebander Biesse Akron 645 running sintra software, but I am having a problem.
Every time I do start the machine I have to go to regulation and set correct value of presser because every start the machine takes 0 as default value.
I am talking for the presser which does press the panels.
So my question is: Is there anyway to save the correct value of presser which normally should be 18mm, and not to SET it every time I start the machine.
Thank you
