Subject: Re: Storing plywood
Storing plywood
3/4/20
Good morning
I use a lot of 1/2 ply prefinished 1 side and wonder if there is a way to store it so the bow is always on the finished side. It's usually not bad but I lose 10% to 15% of the material because it's bowed the wrong way.
3/4/20       #2: Storing plywood ...
What are you using the plywood for? Why does it mater if it is bowed?
10-15% is a lot to not use, I would look at how much extra it cost to get prefinished both sides or finish the side that is unfinished on the sheets that are bowed the wrong way.
You can stack it to promote the bow to go in a certain direction with different thickness of cribbing, but that won’t work for all the sheets as the way plywood is manufactured some sheets will have a mind of their own regardless to how they are stored.
3/4/20       #3: Storing plywood ...
It bows hours after they slap the UV cure on 1 side. There is no real way to stop it. We use it for cabinet backs. The scrap is used for random filler bits that are stapled/glued so a bit of bow doesn’t matter. The 2 sided stuff is still a bit wonky. When we first started using UV prefinish we tried using the 3/4” 1 side for boxes. That stuff was so bowed we gave up. We use the scrap 3/4” 2-sided for shelves.
3/4/20       #4: Storing plywood ...
Dave L
Storage RH/moisture content has to be higher (unfinished side crown, typ.) or lower (cup) than the manufactured RH/moisture content.
3/4/20       #5: Storing plywood ...
It could likely cost about the same for 2 sided when you loose 10-15% of the one sided.
