Subject: Re: Correct type of glue for table top
4/28/20
Troy Beverly
Website: iwswoodworking.com
I'm sure we have all been through this same question hundreds of times, but one more time... 1 5/8" thich island top made of qty.5 8" wide boards. I always use Titebond 2 for open time but keep hearing whispers that I should be using Titebond 3 for " Creep " factors. Any final thoughts on interior island top glue ups ?
4/28/20       #2: Correct type of glue for table top ...
I believe tightbond 2 is fine. I would not use 8 inch boards. You may get cupping and the top will be wavy over time.
What species of wood?
4/28/20       #3: Correct type of glue for table top ...
I would not recommend Titebond 3. Titebond 2 dries harder and is plenty strong and has more than adequate water resistance. Stick to tried and true of your experience.
The only drawback I have experienced with type 2 PVA is that it may expand when using an oil finish. The glue line will bead up over time. I don't use oil finishes anymore.
4/28/20       #4: Correct type of glue for table top ...
Best if those boards are quarter sawn. Most importantly is that it is mounted through slots through the base. Thirdly, finish the bottom of the slab just like the top surface. With plenty of support under it, and plenty of room for it to move, glue selection should be wide open.
4/29/20       #5: Correct type of glue for table top ...
TB3 is more for outdoors as it can withstand the wood movement. That means the glue is more rubbery and creepy.
TB2 is my main glue for just about everything. It is a good choice for the tabletop although hard epoxy or resin glue might be better.
TB1 has the least creep of all the TB PVA glues. A little harder to work with because it dries quicker. But it produces a more stable joint without the benefit of being water resistant like TB2.
4/29/20       #6: Correct type of glue for table top ...
Creep is not desirable, and TBIII is the creepiest glue out there. Also, it fails with heat. Not much heat, either. At 180 degrees, it has lost well over half of its strength. That does not come back when it cools off either.
You want rigid glue lines, and even TBII will creep out of a glue line in time.
4/29/20       #7: Correct type of glue for table top ...
Ken Member
I talked to a rep at AWFS last year and he recommended the TB extend adhesives. Not for the open time but the way it dried it provided a better bond to avoid creep. And he said TB I had the least creep.
4/29/20       #8: Correct type of glue for table top ...
Troy Beverly
Thanks to all feedback. Titebond 1 is my 1st choice always but little scary with huge glue up. Does epoxy have less creep than T1?
4/29/20       #9: Correct type of glue for table top ...
Epoxies should have zero creep. They have a rigid dry line.
4/29/20       #10: Correct type of glue for table top ...
Ken Member
Look into urea formaldehyde resins too.
4/29/20       #11: Correct type of glue for table top ...
We use TB1 for all interior work. Epoxy for all exterior work. Epoxy for longer cure times.
PVA glues can have invisible glue lines. You would have to squeeze very tight to cause starved joints.
Epoxy needs wider glue joints. These can be visible depending on darkness of wood. The correct fabrication method for epoxy regardless of material(wood, metal, fibreglass) is 80grit. It’s a good idea to do a quick soak in coat on miters and end grain.
Using a regular 40 tooth blade gives plenty of tooth for epoxy. We usually run parts thru the wide belt at 80 grit. Delamination can occur in planer smooth layups.
As someone else mentioned you can get some odd TB1 creep things with oil based poly and some waterborne products.
5/1/20       #12: Correct type of glue for table top ...
The odd creep with oil based poly and some wb is TB2 not 1. I’ve never seen a problem with TB1.
5/2/20       #13: Correct type of glue for table top ...
Ken Member
What I said earlier, TB I extend, strongest PVA with no creep.
    • Impact Search and Placement
    • ECabinet Systems
    • Better Vacuum Cups, Inc.
    • Doucet Machineries Inc.
    • Forestry.com
