Subject: Re: Downspiral flush trim bit
4/30/20
Good afternoon.
Clutching at straws maybe...
Looking for a 1/2 downspiral trim bit with a replaceable carbide insert.
Any ideas?
4/30/20       #2: Downspiral flush trim bit ...
Why the need for a replaceable insert requirement?
4/30/20       #3: Downspiral flush trim bit ...
We trim baltic birch and particle board 8 hours a day 5 days a week.
Solid carbide gets expensive if replaced every week.
We need the bearing so we can't sharpen them.
4/30/20       #4: Downspiral flush trim bit ...
The factory sharpened the flush trim bit after brazing the carbide on, so can anyone else. The bearing comes off. Speaking of bearings, you will need a bunch of those too. No bearing will last as long as a couple of replaced inserts. With that kind of footage run, shop for diamond cutters.
5/1/20       #5: Downspiral flush trim bit ...
The problem with the sharpening is the dimensional change with respect to the bearing.
Insert carbide is harder so will last longer but I did not see any down shear
5/6/20       #6: Downspiral flush trim bit ...
Chuck Hicks Member
Just a thought, Along with the downcut spirals. We offer a bearing that is .490 in diameter that will allow you to get a couple more uses after the bit is sharpened a couple of times.
