Subject: Re: Shaper fence setup
Shaper fence setup
11/23/19
MarcP
I put this indicator set up on the shaper fence to align the outfeed side of the fence to the cutter head. Made setup super easy and accurate. I offset the fences about 1/16-3/32 to make a full cut when running cabinet door parts and indicating the fence to the cutter produces very straight parts. I’m finding machinists tools really help for machine setup. I’m mostly self taught and have learned a lot from here, hopefully this will help someone else.
11/23/19       #2: Shaper fence setup ...
I need to invest in more fine measuring equipment.
We do an adjustable outboard fence for sticking and sizing both face frame and door parts. It'd be tough to set up like we have on a rolling top like that though
I have kicked around setting up another shaper with offset fences to act as a jointer to straighten out whatever curls up after the slr.
11/24/19       #3: Shaper fence setup ...
Typically you take a ruler and set the infeed table so it makes your 1/16 cut. Take a sample piece of wood 16”-24” lond and do a free hand test cut about 6” in length. Set the outfeed table using that test piece.
We use a basic outboard fence when sizing cabinet parts. Faster setup and more accurate.
11/24/19       #4: Shaper fence setup ...
RichardP
I second Adam, much better way for both setup and straightening and sizing. Sizing anything by removing a set amount makes no sense.
11/24/19       #5: Shaper fence setup ...
MarcP
I never mentioned anything about sizing parts in my post. I do occasionally use an outboard fence to run door parts, but sometimes when running door/end panel parts for a kitchen you will have stiles and rails of different widths which would mean moving the outboard fence for each width.
This method is no more difficult or time consuming than using a straight edge and there is 0 error. No chance of snipe, or cutting bows or tapers into the door parts.
11/24/19       #6: Shaper fence setup ...
All you are doing is getting the outfeed fence in-line with the cutter head. That can also be done with a stick of wood and get it within .001 at least by eye. The challenging step is to get the inboard fence/cutter head/outboard fence all working together.
We’ve got all of the machinist gauges. We only really use dial/digital calipers. I can setup jointer knives with a stick of wood with pencil marks faster than my dial indicator.
The issue you run into with wood is we are moving the material versus machining fixed pieces of metal. The reality is the cut matters not how it’s all measured.
Sharp pencil line is 1/64”. Cut it in half on a miter saw and you are at 1/128” accuracy that’s .008” by eye. Machining on a lathe or milling machine is typically .001” accuracy.
11/25/19       #7: Shaper fence setup ...
Bill Member
Depending on your budget a Shaper with an NC controlled fence and spindle make it a different machine. The up front cost is significant. If you are doing it right your tooling is all insert carbide and you need spindles (HSK63F) for all your setups (you can stack tools on each spindle).
We have this setup, because you have such fine control of the fence and spindle setting up the tool the first time is easier than a traditional machine. We could not do what we do without it. You can walk up and make a few sticks of anything in minutes. Anyone can be successful with it.
We also have a few dedicated shapers for high volume operations.
I realize this is not for everyone but if you reach the point where it makes sense it is a game changer, go and don't look back.
11/25/19       #8: Shaper fence setup ...
Marc, our outboard fence has digital readouts. Two clamps hold the fence that rides on cheap linear bearings.
Adjustments are quick, easy, repeatable, and accurate.
11/26/19       #9: Shaper fence setup ...
Used to be, and probably still is, when you buy a top of the line Weinig, they give you a nice 12" straightedge to set up with. Nothing more. Intimidating until you know how easy it is to use.
It is used as Adam describes. Same as a jointer set-up, with setting the outfeed table in line with the knives.
A shaper with DRO fences is a dream for us, but then we only have a few repeatable set-ups, but it would be heaven to have those so easily set.
My machinist (?) tools, in the order of usefulness:
Starret digital calipers - perfect
Infra-red thermometer - perfect
Dial indicator with base - mostly good for head/knife projections on the shaper.
Digital readout protractor - Starret, but it is still junk that eats batteries.
Dial indicator caliper - plastic and worn in places. Metal is far better.
Vernier caliper - Can't see the graduations much anymore.
Planer and Joiner knives are set with static gauges.
5/8/20       #11: Shaper fence setup ...
Al Gerhart Member
Split fences are great for shapering door edges but stiles/rails need cut on an outboard fence. I took a 5 hp grizzly shaper, set a bolted down 3/4" thick MDF fence about ten inches away from the cutter. Next plain down some maple stock to 5/8" and make your sub fences. We made a half dozen or so widths from 2.5" up to 6" wide. Drill two 1/4" holes through the shaper table to bolt down the sub fences.
In use, I bolt down the front bolt for long runs of 2.5625" (from 2.625" wide stock), then if you need a 5" rail for an end panel you unbolt a single nut, pull the 2.5625" sub fence and drop in the 5" and just drop the bolt through the hole and run the parts. Takes a minute to pull the original sub fence and be back to work running the 5" stock.
No measuring needed once you make the sub fences. Extremely accurate and cheap to make.
2/23/22       #13: Shaper fence setup ...
Tom Leonard
    • Anver Corporation
    • Doucet Machineries Inc.
    • RT Machine Co.
    • Lockdowel, Inc.
    • Denray Machine
    • The Millwork Studio
