Subject: Re: Shaper loosing power
6/4/20
Tadhg
Hi all I have a Powermatic pm 2700 and lately when I run material through it the machine will loose power in middle of running material through it which means I have to hit green button again to keep it going. I can not figure out how this is happening without hitting red stop button has anyone had same type of issue thanks tadhg
6/4/20       #2: Edgebander loosing power ...
Tyler
We had an edgebander back in the day that would do the same thing. It turned out that we were putting too much pressure on the panel.
6/4/20       #3: Edgebander loosing power ...
Tadhg
Sorry tiler the machine is a shaper the heading is a mistake
6/6/20       #4: Edgebander loosing power ...
Stephen Williams  Member
Website: http://www.partscuttercnc.com
Mo chara
Is it dropping a leg? Check out the magnetic starter, could be burned.
Steve
6/7/20       #5: Shaper loosing power ...
bill
had the same problem a few years ago. After going crazy chasing a ghost and in the midst of it we installed a CNC router and had the same problem with the vacuum pump. I called the power company, turned out to be a loose connection at the transformer.
6/7/20       #6: Shaper loosing power ...
CGiles
I had this happen on my shaper years ago. The third leg of the 3 phase turned out to be the culprit. For some reason, the thing would start and run, but had no power. We corrected the wiring, and its been a beast ever since. Also, paste wax on the table helps.
6/7/20       #7: Shaper loosing power ...
pat gilbert
Check your circuit breaker
6/7/20       #8: Shaper loosing power ...
Like others mentioned, sounds like a power issue, could be motor , breaker or main supply issue. If only the one machine is acting up it is most likely between the breaker and the machine. I would put my money on a motor issue, but check the breaker and wiring as well. Get a good voltage meter and get some one using the machine and start trouble shooting, there is not that much to check so you should find the problem in no time.
6/7/20       #9: Shaper loosing power ...
Tadhg
Thanks guys I will check all these and see how I get on with it Tadhg
    • Impact Search and Placement
    • ECabinet Systems
    • Better Vacuum Cups, Inc.
    • Doucet Machineries Inc.
    • Forestry.com
