Subject: Re: Hidden passage way
Hidden passage way
6/12/20
Hey guys and gals, I have to estimate a job where there’s a hidden area behind it. I need to come up with a pivoting system to mount a bookcase of sorts. Half of the wall will be a stationary location and the other half will be in the operable pivoting bookcase. What have you guys used to pet a secret passageway? With or without actuating casters? Thank you ahead of time for your guys home
6/12/20       #2: Hidden passage way ...
Mark
Depends on the swing and the weight really.
could be as simple a Harmon hinge opening with a caster
6/12/20       #3: Hidden passage way ...
Link to a harmon hinge?
Approx size is 20 w x 15 d x 48 tall
6/12/20       #4: Hidden passage way ...
Mark
http://www.harmonhinge.com/
6/12/20       #5: Hidden passage way ...
Mark
At the size you listed, a heavy duty piano hinge could probably carry it
6/13/20       #6: Hidden passage way ...
Collin Parker  Member
Website: heritagewoodwright.com
https://murphydoor.com/collections/single-doors
here
6/13/20       #7: Hidden passage way ...
Mark
Yep, Murphys' even easier, less expensive
Gotta love that disclaimer
6/14/20       #8: Hidden passage way ...
keith farr
Check out the rixon pivot hinge Use them often nand can carry much weight
    • J&P Machines
    • CabMaster Software
    • Lignomat
