Subject: Re: Pressure treated plywood
6/24/20
Terry Stone Member
When bidding on jobs, I keep finding specs that call for the sub-tops in wet areas to be pressure treated plywood. The problem is that I have never seen or heard of a pressure treated plywood that would be suitable for applying plastic laminate over. Has anyone else had this problem or know where one might find plywood like this?
6/24/20       #2: Pressure treated plywood ...
Use Medex. It's a water resistant MDF. Or you might be able to use Extira which is a water proof exterior sign material. Not sure how it would perform for a laminate substrate.
PT plywood under laminate is just asking for trouble from the stuff I've seen. Never seen a cabinet grade PT plywood.
6/24/20       #3: Pressure treated plywood ...
They are mislabeling it. The spec should be moisture resistant.
There are MR particleboards available for that application.
Medex offers similar protection.
They make MR melamine for baths. Not that you would use it for countertops
