Subject: Re: router bit
router bit
7/9/20
ennisdavis Member
Do they make a router bit that had a large bearing and a small cutter. I would like to drill a hole in the work and route around where a door was, leaving a 1/2" lip and the center piece falls out to be used somewhere else.
7/9/20       #2: router bit ...
Mark
Anything can be made, talk to a sharpening shop
7/10/20       #3: router bit ...
TonyF
ennisdavis:
Is there some reason that a router bit with a large template bushing on the router base would not work? You could use this with a plunge router and have a neat job done on both the door opening and the removed panel.
Perhaps I do not understand the project at hand.
Hope this helps.
TonyF
7/10/20       #4: router bit ...
Mark B
I think your looking for an overhang trim bit for laminate?
https://www.toolstoday.com/v-14293-47198.html
7/10/20       #5: router bit ...
daniel wipf
basically any flush trim bit with a bearing on the end... just swap the bearing for a larger one. there are many different size bearings available.
7/12/20       #6: router bit ...
They Member
Yes, we do. Contact us at our website:
Routerbit@they.com
Ask for They.
    • GreCon
    • WalzCraft
    • WOODWEB, Inc.
    • American Vision Cabinets
    • J&P Machines
    • O'Shea Lumber Company
      Merchants of Fine Woods
