Subject: Re: Jet WSS-3-3 shaper bearing question
8/11/20
Al
I would like to replace spindle bearings on Jet WSS-3-3 shaper. Anyone know the procedure?
Thank you,
Al
8/12/20       #2: Jet WSS-3-3 shaper bearing question ...
I want to be a dick and day pick up the machine with a forklift, then set it carefully in the dumpster. Unload a real shaper with the forklift.
Should be straight forward. Pull the quill assembly out, remove the nut on the bottom holding the pulley, remove the snap ring building the bearings, everything slides out the bottom except the top bearing. I'm pretty sure it's identical to the Powermatic design.
8/12/20       #3: Jet WSS-3-3 shaper bearing question ...
Bryan Dever- Sawtooth, LLC
Website: http://sawtoothcabinetry.com
Rebuilding the cartridge is a little more involved than most guys realize. I just had my Delta rebuilt be a really good guy. His name is Rich at A&E tool. Give him a call. It is a quick turn around. 817-455-7449
    • J&P Machines
    • CabMaster Software
    • Lignomat
