Subject: Re: Side mount soft close drawer slides
10/21/20
Tom Gafgen
I have an odd situation where I can't use undermount slides on a very shallow pencil drawer on a high end desk . Can anyone recommend a brand of side mounts with softclose that work well ?
10/21/20       #2: Side mount soft close drawer slides ...
I have used Accuride on some commercial Applications, I think they are a top brand. I have only used ones that are 20 inches so not sure how short of a slide they offer.
10/21/20       #3: Side mount soft close drawer slides ...
pat s gilbert
FWIW my experience with the accuride was that the were mediocre at best, albeit the last time I tried them was 7 years ago
10/21/20       #4: Side mount soft close drawer slides ...
MarkB Member
The best I have found so far (but they are still pretty much a side mount) is Vadania. Expensive, but seemed to be the smoothest I ever found. I tried several of the standard players, accuride, KV, and a couple imports. None of them run anything like an undermount but once you engage the soft close feature they do pull the drawer shut. I was always looking for the silky smooth of an undermount but there so much going on in a side mount it never happens.
10/22/20       #5: Side mount soft close drawer slides ...
david zaret Member
i've had a terrible time with the accuride 3832 series with soft close. the non-soft-close are great, but the soft close have been horrific. look elsewhere, IMHO.
10/22/20       #6: Side mount soft close drawer slides ...
Nathan Wesseling Member
I've had horrible luck with side mount soft closers. I had a sales rep come in not to long ago talking about these. He actually said that accurides aren't designed to be used in a drawer wider than 24". When you go on accurides website it actually says 16". I'm sure its the same for other brands as well, as there isn't really anything tying the slides together you can twist the drawer easily while opening or closing.
10/23/20       #7: Side mount soft close drawer slides ...
NSLJAW Member
I've used KVs (Knape & Vogt) with pretty good success. If money isn't an issue I'd suggest going for something with a higher weight rating than you need since many "lightweight" or "light duty" soft close slides I've used have the cheapest plastic parts in the mechanism. Once they're installed they're great but I've found they're most likely to break or have an issue when the drawer is being reinserted (or "locked") into the guide after mounting. Be gentle just in case.
And not that you asked, but when mounting soft-close side mounts to the cabinet I've stopped putting any screws in the middle holes and only put them at the front and back of the guide as many I've used won't flow as smoothly (or at all, on occasion) if they're forced to flex to whatever little amount of bow might be in your material. This hasn't been a big deal with non-soft-close but soft-close need to be as straight as they can be in my experience and this may matter as much as brand quality.
10/24/20       #8: Side mount soft close drawer slides ...
Quicktrim
Worth louis and co has a nice soft close side mount , works well if you build a square box .
    Lamello
